New Pro drivers SB Audience from SB Acoustics
I have to say that I find the datasheets etc a little disappointing.
Take a look at the 15" coaxial, for example. The HF response is rather ragged, and actually dips below the woofer level for part of the range. Combine that with a Qts on the high side, weirdly-low impedance (Re=2.8ohm!), and very limited power handling, and you've got a driver that I just wouldn't be excited to work with. They haven't even specified the coverage angle.
The 6" coaxial is interesting, but the rest of the range look like they could be equalled by the Eminence Beta-CX range. Those are old-school, low-tech drivers.
There are a couple of interesting drivers in there - the high-end 21" subwoofer looks pretty respectable - but the majority of the ones I clicked on looked behind the curve.
They might save themselves by being very reasonably-priced, but apart from that, I just can't see them getting into the market with the current offering.
Chris
Certainly not all disappointing. The Nero woofers look pretty state-of-the-art.
The NERO-12MWN400D is a 12in mid-woofer with an Le of .22, with a good looking response. SB's curves are normally very reliable (versus the crazy smoothing you find with competitors). Apart from Acoustic Elegance, I don't know of another product with those numbers.
The Nero midrange (NERO-6MRN150D) also looks great. Flat foam surround, good ventilation, all the signs of a great motor. 98db efficiency. Looks great for a 3-4 way.
I read they have 3 distinct lines: The Bianco is a budget, low cost offering. Rosso is a high value (great performance at a middle-cost). Nero is their TOTL products.
Right now, they only have Bianco compression drivers listed, but I imagine they are working on Rosso and Nero HF drivers. One thing I did like was the fact that they post the exit angle on the drivers. I imagine they aren't the only one, but I cannot recall seeing that data from competitors.
