Spawn Kongo enclosure damping question...
Morning!
Just finished the build of the enclosures and am listening to them now.
Have done some rootamentary damping, wondering how folks have approached theirs?
Using Fostex FE108Sigmas in the enclosures.
Thanks for any thoughts you might have to share.
P
They are playing now, and I'm really loving them!
Tremendous sounding speakers. Crazy sound from a 4" driver!
I have all the wood cut for the Kirishima as well. Am building for a friend. His FE206EN's have been breaking in all week. Vet excited to hear those.
As far as I know, as Dave says above, most have simply lagged the walls of the driver chamber. That's the default, any additional will vary from build to build, so once you've installed the default, I'd seal them up. You can always add a small amount to the final part of the horn later if you prefer.
Thank you! I did, and added some in the final part of the horn. Did not put any on the actual motor board. Also added a small amount of poly fill in the chamber. Screwing in the side panels helped a lot! So pleased with these.
