Imgstageline MCX3210 crossover opamp update !!!!!
Hi guys,
I have this 3-way crossover + sub output, I thought to make an update of it by replacing all the opamps present, they are BA4560. My idea of ​​soldering dip8 sockets and so being able to insert and remove opamps. Do you think it's worth it? which opamp do you recommend affixed to the BA4560 type plug and play?
Not expensive enough.
.... strange, I have not heard much good about the AB4560 .... I have also attached the schematic
If there were 60.00 USD discrete opamps you could read reviews where substituting these in changed peoples lives. Poorer but happier.
Two easy mods, Bypass C33 and C37. Also I see no local decoupling for the opamps. Add some close to the opamps. Being through hole construction add some small value caps close to the opamps.
Search here at diyaudio for ideas and recommendations.
thanks for your advice....
