Spare part for Keysight o´scope
I need a smps module for my Keysight scope (warranty expired) and Keysight says I have to send the scope for them for maintenance, 600 miles away from my city.
The problem is already determined and I just need the module. Does someone know if there is a supplier for these parts?
I can´t find suppliers browsing by Google.
Regards and tks in advance,
Often these supplies are only OEM, but remove it and post photos here.
Have you substituted a known good supply from another unit, which worked?
If not, there could indeed be other problems. If this is an older scope,
it may be more cost effective to buy another working used scope.
Which model is it?
Which model is it?
It´s a DSOX2002A, still in production. The module is this, and it's hard to replace with another type.
It's doubtful that this supply would be available anywhere other than Keysight.
Suspect the Keysight repair cost to be around half the cost of a similar, replacement used scope.
Older used Agilent 100MHZ two channel scopes run $200-$300.
