help wiring Quad-gang pot for stereo crossover
Hello guys, i'm building a stereo crossover from Elliot Sound products
'Isolator' Equaliser
I'm not totally sure hot i have to connect the 2 quad-gang potentiometers which allow me to switch the crossover point. (2 sections of a pot will control L channel, the other 2 will control R channel)
I picked 2 of those dentent pots
https://www.mouser.it/datasheet/2/54/ptd90-777943.pdf
Attached you can see how i would wire it. do you think is correct?
i attach the original schematic from ESP as well.
thanks for any help🙂
You know the little arrow on the pot shows clockwise direction? As shown these will have maximum resistance at fully anti-clockwise, so that clockwise rotation reduces resistance and thus increases the cross-over frequency.
Ideally the pots would be reverse log taper, but linear will probably do.
Hi Mark thanks for the reply. do you mean the grey vertical arrow? i will check now, i haven't seen those before.
basically this means that i have to connect them the other way around then? (CW input, ouput is the wiper which is connected with CCW.
or is totally wrong?
