Aleph J - First Test Issues / No Sound / Blinking LEDs
Wowbagger: Forgive my inexperience. Do I measure that from the outside pins?
Yes - the schematic shows that the middle pin is connected to the lower (outside) pin. The voltage across the outer pins is the voltage seen by the lower output devices (the ones you're measuring the bias on).
Since the latest development (22.9V on the output), what's the voltage across R8?
If the lower ZTX (Q3) is bad, it might be shorting to the lower rail, bringing the input on the lower MOSFETS to V- and preventing any bias current from flowing. Q3 can be removed and the amp will be functional - Q3 is a safety feature to limit peak output current, but it is not required. If you remove Q3 and the amp works again, then you've found your problem.
What is the voltage between the jumper R6 and the leg of D1 closest to Q2? You should see about 0.6 V
If Q2 is bad (or if there's as soldering issue), and shorting these points together, you'll get about 8.5 V over R8 and 20-ish volts on the output (according to LTSpice).
The other explanation is that Q1A isn't conducting, but that's an expensive problem...
Options:
1. Wait until you order more ZTX parts and replace Q2.
2. If you remove the jumper R30, you can use your multimeter in ammeter mode to measure if there is any current passing through Q2 by inserting your probes where the jumper was.
+ If there is ~8.5 mA, then Q2 is working, and the current isn't passing through Q1A, since you've measured 0 V on the offset pot, which follows Q1A (EDIT: Unless the pot has failed and has zero resistance). This will give 20 V + on the output. This would suggest concern about Q1A.
+ If there is 0 mA, then Q2 is your problem. (EDIT: or Q1A - if Q1A fails to conduct, then Q2 won't pass current either).
I measure 243R across R7. When I adjust the pot it doesn't change. Is that normal?
243R in that position would also give ~20V on the output. Is there another pot you can substitute in? It should change when you adjust it. I don't see any other parts other than the mosfets that would be parallel in the circuit - the pot should be the only thing between the probes, so I would expect the resistance to change.
