Thanks,But i found some noise using this arrangement
What kind of noise, huuuumm
apex fh11 with 3pair of irf640n/irf9640n
apex FH11 with 3 pair IRF640N/IRF9640N:
PCB BY: INSTAGRAM@ASHKAN.AUDIO(hassan4119)
SCHEMATIC BY: Mr Mile Slavkovic
mr mile slavkovic This is my gift for friends here and to compensate for your efforts.
zip file is PCB top and bot.enjoy
Very nice build hassan. Very very compact and symmetric looking pcb too.
Congrats!.
I am planning to make it with single pair version , I have posted the design somewhere in recent pages, which will be diy friendly, though I am planning to manufacture them in 2.4 mm , 70um copper. However due to lockdown, its on hold.
regards
prasi
Congrats!.
regards
prasi
tnx mr prasi...i see your pcb too....your pcb is very nice too...Very nice build hassan. Very very compact and symmetric looking pcb too.
Congrats!.
regards
prasi
i made apex ax17 with to3 and bjt...full symetricall and very very compact.
ax17 with to3- 2pair
with permission from mr mile slavcovik:
apex ax17 with to3 transistor in
Running out
high compact in one layer
mr mile whats maximum voltage for 2 pair mj15024/mj15025?
and about 2 pair MJ2955/2N3055?
i use TO3 pack for To create a nostalgic state.
Running out
Gerber attached, Board have been tested....Work perfectly and Ready to be add to my new A40 Project
Running out
I like this, alot. Transistors are easily available, I have tons of them MJ2955/2N3055
if they are original plz take a pic and put to we enjoy that.I like this, alot. Transistors are easily available, I have tons of them MJ2955/2N3055
I never built it yet 🙂
Anybody got the latest working pcb layout for the APEX AX17?
i made ax17 with bjt transistor one pair go for ax17....nice sound
Another FH9 soon to be born 😀
I’ve got one FH9 channel powered up and singing away 🙂
Currently using a linear psu feeding 43vdc @ 90mA bias. DC offset, although not adjustable, is more than acceptable at 10-12mV. I’m recycling an old amplifier chassis, therefore the odd device mounting is because I am utilizing the existing tapped holes 😉
Easy peasy build and really sounds pretty darn good with nice bass weight. Looking forward to getting the second channel fired up to get the full FH9 demo.
Humming.. What the cause? I use dr bora flatbt buffer.
Nice work Vunce! Can’t wait to hear your listening impressions after you go stereo. Wondering how this little amp stacks up to your other Class AB reference standard amps.
- 100W Ultimate Fidelity Amplifier
