Problem with buffered opamp HPA
I've built this headphone amp as detailed here and I'm not getting any sound out from it. I can feel (through my cheapo headphones used for testing) that the driver gets warm.
The power supply is OK, feeding +/-12
I've done some basic checking - so as far as I can see all polarities are observed and the correct parts installed according to the BOM (the empty holes are for optional diodes according to the BOM).
I've cleaned the boards again and checked for obvious shorts.
I've swapped out the BUF634s and LM4562s
What should I look for now?
D1A and A1B are not placed, both anodes to the gain-amp outputs, cathodes to the minus rail. Odd that is.
Remove the opamps & buffers and check for wrong dc voltages.
Verify all solderings on the (upper) ground plane and make sure they're connected to the 0V from the power supply (I had once a serious time lost finding this stupid mistake of myself...); you cannot see if the soldering under the power connector is ok - the power connector sits on top of it. Same applies to the attanuator, but if the ground is missing there you have no attanuation at all, only maximum volume.
Thanks for the hint MarsBravo.
I removed the opamps and buffers and checked for DC. On the LM4562 I discovered the + wasn't going where I thought it did! Upshot, the LM4562 has the +V on pin 8 whereas the board is configured for +V on pin 7.
My own stupid fault for not checking the datasheet. The original article called for a LME49710 which I couldn't get and I had it in my head that the 4562 was the same chip, but it is the same as the 49720. Live and learn.
Thanks again for taking the trouble to look.
Yes, this is a trap for the unwary, single and dual opamps in 8-pin packages have different V+ pin. Many single opamps have different compensation and offset schemes anyway so as always remember to check the datasheet for every part. (Having said that dual opamps in 8-pin packages seem always to be pinned-out identically).
Another trap that can get you is quad opamps v. quad comparators like the LM339 - totally different pinout.
Lesson learned!
In some ways it's good to have things go wrong, it (hopefully) makes you more diligent next time and you always learn something, which is always good.
