Hi! Looking for an already assembled crossover (2-Way 2nd order 8 Ohms 525 Hz). Eminence used to have the PXB2:500, which was crossed at 500 HZ and would have worked fine, also crossed at 600 HZ would have been a suitable alternative, since it is a hybrid speaker (woofer in a vented enclosure and full range driver in open baffle configuration), but they have discontinued those lower range 2-Way crossovers, and now they start at 800 Hz.
Please, can someone point me to a crossover assembler or a company that might have those low Hz crossovers?
Just sub larger bipolar capacitors on this one that you mentioned. The HP is actually 3rd order.
Eminence PXB2:800 2-Way Speaker Crossover Board 800 Hz
Thanks for taking the time, I already went that route. As mentioned in my post, 800 Hz is the lowest frequency Eminance has for 2-Way, but NOT what I need. I need between 500 and 600 Hz, 2-Way 2nd Order, 8 Ohm.
Low Pass Speaker Crossover 500 Hz 12 dB/Octave $17 - Dayton Audio 500-LPF-4 Low Pass Speaker Crossover 500 Hz 12 dB/Octave
High Pass Speaker Crossover 500 Hz 12 dB/Octave $15 - Dayton Audio 500-HPF-8 High Pass Speaker Crossover 500 Hz 12 dB/Octave
Did see that, it might be the way to go. Thanks
