Hello,
Like new, great but very heavy unit.
The shipement cost :
28,55 € for the France
61€ for the EU
XX€ for the world
https://nsa40.casimages.com/img/2020/04/17/200417054825998182.jpg
https://nsa40.casimages.com/img/2020/04/17/200417054826391923.jpg
3.25” Voice Coil
2000 Watts Peak Power Handling
Ferrite Magnetics
Precision Circular Inside/Outside Wire Geometry
Die Cast Aluminum Chassis
Small Signal Parameters :
Nominal diameter : 381 mm/15 in
Power rating : 500 W(AES)
Nominal impedance : 8ohm
Sensitivity : 97 dB
Frequency range : 45-3500 Hz
Chassis type : Cast aluminum
Magnet type : Ferrite
Magnet weight : 29 kg/1039 oz
Voice coil diameter : 825 mm/325 in
Coil material : CCA-W
Former material : Glass fiber
Cone material : Paper
Surround material : Cloth
Suspension : Single
X-max : 4,8 mm/019 in
Gap depth : 100 mm/039 in
Voice coil winding width : 196 mm/077 in
Net Weight : 10,2 kg/225 lb
Packing Dimension WxDxH : 430 x 430 x 220 mm
Shipping Weight : 11,3 kg/249 lb
Re : 5,5
Fs : 41 Hz
Mms : 90,0 g/317 oz
Mmd : 74,95 g/264 oz
Qms : 4,21
Qes : 0,41
Qts : 0,37
Vas : 183,44 lt/648 ft
BI : 17,76 Tm
Cms : 17e-04 m/N
Rms : 5,51 Ns/m
Le (at 1kHz) : 0,43 mH
Sd : 881 cm2
61€ for the EU
XX€ for the world
3.25” Voice Coil
Ferrite Magnetics
Sensitivity : 97 dB
Suspension : Single
Re : 5,5
Fs : 41 Hz
Mms : 90,0 g/317 oz
Qms : 4,21
Qes : 0,41
Qts : 0,37
BI : 17,76 Tm
Cms : 17e-04 m/N
Rms : 5,51 Ns/m
Sd : 881 cm2
Shipement for the world outside of the EU :
Eastern European countries (excluding EU), Norway and Maghreb : 73,60 €
African countries (except Maghreb), Canada, United States, Russia, Near and Middle East : 168,00 €
Sorry for those who are far from France, this loudspeaker driver unit is really great for the price 😀
Hi!
Is this a single driver? Cheers!
Ps, very generous 🙂
Yes, single, used in an open baffle test from 40Hz to 60Hz with a TPA3116 of 20W. Very underrated unit IMHO.
I can't make a rebate !
Yes you can ! free shipping 😛
Just kidding..
Just kidding..
Ok, free shipping at my door 😀
The loudspeaker is reserved to "guyome"
