Samuel Gromer low noise opamp
I did read that already somewhere on diyA and echoed it, but someone
else on diyA with apparently a Philips history claimed that diffusion was only
here in Hamburg, Germany in the old Valvo fab and in Asia was only post production.
I have moved to ON CPH3910, but still ~150 BF862 in the drawer.
No noise tests for the 3910 yet. Should have ~30 Hz corner from the data sheet
and very small capacitance.
The 3910 spice model has no 1/f.
My application for low noise transistors was for a microphone preamp (~310Ω source impedance @ 1.6mV nominal), with existing PNP TO-92 topology. The best I found was a ZTX 550 (with a ZTX450 complement) which would get to ~74 db S/N. I used the chart from "Art of Electronics" by Horowitz-Hill, which has an EXCELLENT section on this very topic.
I have built the ribbon mic amplifier from AOE3, or really half of it, i.e non-differential
with ZXTN2018, and only 16 transistors instead of the 64 of the diff version.
The ZXTN2018 has SMD code 851, wich probably means that it's the same chip
as the FZT851, only sot-23. It delivered the promised 70 pV/rtHz, but needs
low input impedance because of noise current.
I wanted it for a chopper post amplifier, so the input capacitor is not an issue.
Hey, the chopper transistors are GaN, 1 square millimeter with 4 bumps, no case. 🙂
I could solder that but first must flush my pipeline of uncompleted things
b4 continuing.
The GaN-FETs are the small dots between the huge SOT-343 clock drivers on
the left and the 4 coupling caps.
One thing I will note is that the 2.4V reference comes up a bit short -- around 2.1V -- probably not enough current to drive Vf to 0.6V
Got that fixed.
Here's an FFT -- I also experimented with a DMOS CCS -- much worse as illustrated below. Incidentally, the FFT and the Analog Bandpass method yield results within a very small percentage error.
Here it is in one of the smaller cookie tins -- I have found that the heroic measures taken by Linear Tech don't seem necessary -- no need of a mu-metal canister, just the cookie tin, and the smaller tin is better for the waist-line:
I must say that Jan's "Silent Switcher" makes the Lithium batteries exhaust themselves in about an hour's worth of work.
It was me.
They were diffused on 4” only in Nijmegen and never anywhere else.
Assembly was in a HK for many years and then at a second site at the Guangdong assembly centre from about ‘96. The HK assembly centre was closed down in about 2002/2003 IIRC. I can’t recall what the assembly centre markings were unfortunately.
Hamburg was always only bipolar small signal - never FET products.
Why 4” ? Because that’s what they were developed on back in the day with some other RF parts and once you have an RF process running smoothly you don’t mess with it.
They were discontinued in 2014/2015 (who needs discretes anymore?) but sold off reserve stocks for a year or two. I think Mouser showed them as obsolete in 2016/17.
I have 1000 private stock.
Sorry Gerard - unfortunately I left in 2015.
The business - like any semi business - has to be brutally focused on what makes money so there’s little incentive to keep parts in the portfolio that have marginal sales, or that won’t payback quickly if a fab transfer is involved. I remember trying to explain this to Charlie Hansen. It’s a totally different world to consumer electronics, Audio etc.
A lot of the guys I knew have moved on - that business was split off about three years ago and is run as a separate independent entity now (with power mosfets* and some RF stuff now on 8”).
*high performance stuff for auto and telecom
Anyway, enough - let’s get back to low noise opamps!
I built a version of the HP403 high impedance buffer using ZTX951. It was indeed very low noise (couldn't really come up with a number, but with the IF3602 amplifier it didn't increase the noise level more than a squiggle). Nevertheless, I couldn't get the input impedance above some 10k Ohms, whereas HP specified Zin of 2Meg.
I don't want to lead this thread astray, perhaps a more generalized LNA thread.
Some fodder -- I used a 60 Ohm resistor on the input -- first image has the top on, second with the top off. amplifier housed in a Oreo cookie tin, powered by Jan's "Silent Switcher" and Sam's low noise current source and 2.4V reference:
