Unknow mosfet
i have tryed with hi-power. this is the situation with oscilloscope.
After 20sec. was broken.
i have used IRF540N
Did you try lowering the 12v supply voltage as I suggested n post 13 to see if the PS waveform changes?
i have this situations
other thing, without remote, i have VBATT on drain pin of powersupply mosfet, it's normal?
I don't see anything out of the ordinary. This is a regulated power supply and the pulse width appears to be changing as expected with a change in supply voltage. If you check the rail voltage with the varying 12v supply voltage, you're likely to see no change in the rail voltage.
The waveforms on the drains of regulated power supplies vary greatly and unless the regulation has reached its limits, the waveform won't look like those of an unregulated power supply.
I think it's OK but when I work on an amp, I don't care what the drain looks like. It varies greatly for regulated power supplies. I look at the gate drive. That's what's important. The only time I'm concerned about the drain waveforms is if there is evidence that there may be excessive ringing (causing snubber resistors to overheat).
The ±17 isn't significant but the ±56 is. That's more than 100v across the rails for FETs that are rated for only 100v. I would expect something more like ±35.
What is the DC voltage on pins 1 and 2 of the PS driver board?
