sony ta-n86b power supply help please
Being looking at this board for a few hours checked all transistors and change most diodes
i marked the voltages i am getting at test points
could anyone take a look and send me in the right direction..
most of the voltages are twice what they should be see attached
thanks so much for any help
...looking at this board for a few hours...
So I did, and found that this power supply is notorious for its problems. I solved the puzzle by removing it althogether and have it replaced with four (domestic tungsten/halogen light) transformers, a massive Greatz-bridge and a bank of eight tropic-grade capacitors. And a relay to switch between A and B (2x12V in parallel vs 2x12 in series, per rail). It plays.
Keep in mind there are two main variations of this supply: the 110V and 220V versions. Not knowing where you're from, I supplied the EU version below. If it is a 220 version on 240V, you get 9% higer values (131 is close to measured 134).
Drop me a pm for a extensive Service Manual.
