Chassis mounts of resistors etc
Hey everyone. I've seen on some amplifier builds there are these chassis mount rails where resistors and capacitors are mounted on them for the high voltage components. Does anyone know what they are called? If not, can anyone recommend a way to mount all those components inside the chassis?
Thanks.
Do you mean like this? This is a "Turret Board".
I just wire things point to point or use terminal strips...
If your wanting to mount them directly on the chassis you can use something called a standoff i don't think they make them anymore but you can get them insulated and not. insulated means that when you screw it to the chassis it's not electrically connected.
