their tweeters seems to be popular among many mfr's, a few seems to be using their mids and subs, but i have not seen one using their woofers
Piega using SS Disco woofers, even Magico in their S serie used Discovery subwoofers as woofers up to 300 Hz or so.
Which Scanspeak and which Magico ? i checked the Magico S series and could not find the matching woofer from Scanspeak
yes, their subs are used by a few, but their woofers are rarely used, i must check out those piegas
magico s5 woofer looks a bit like a discovery subwoofer
Dustcap looks different, unless they replaced it
Magico S5 MKI used a modified 26W/4558T00 in 8 Ohm version and another dustcap, MKII uses SEAS units for bass.
Suesskind Beo uses stock 26W/4558T00.
Piega Classic 80.2 uses stock 26W/8534G00 woofers.
Bang & Olufsen Beolab 90
Very good example, one of the best commercial home loudspeaker that exists.
Thats a great bit of info. I have the 8 ohm version and it has v good sealed response, so can see why it was chosen.
Other manufacturers using scan -
Wilson Audio. They esp like the coated rev 15W
Also GamuT, Fritz, Sony and some older Sonus Faber models
How did you get the 8 Ohm version? I know it’s not made for store shelves, only 4 Ohm version that is available.I have the 8 ohm version and it has v good sealed response, so can see why it was chosen.
Are you sure it's a 26W/4558T00 in 8 Ohm version like 26W/8558T00 according to SS naming schemes?
- Which commercial brand uses Scanspeak discovery drivers ?
