Next is a Tripath 2024 based amp in a nice jewelry case, includes the power supply.
Included is a PJMiaolai M1 Tube 6J9 based Headphone amp. Woks fine - both use same 12v wall wart power supply
$30 + ship or pickup in west sub of Chicago?
How much for shipping for these two?
To zip code 32725 ? Deltona Fl
What’s the lowest you would take for the
Matisse Fantasy Tube Preamp ?
And what does the Musical Fidelity X10 Tube buffer Clone do ? Is it any good for hooking up between a turntable and the preamp?
The Matisse is ready to go - has trannys for B+ and heaters, and has the 5670 tubes.you jut need to put your mains fuse and plug on and your good...need $80
The Musical Fidelity X10 Clone is a tube buffer - no/little added gain, just lowers output impedance, The MF X10 was called "The Missing Link" and was designed to be added to SS gear (usually between CD player and Preamp or Preamp and amp) to make it sound more Tube like...see sterophile review
Musical Fidelity X-10D line-level preamplifier | Stereophile.com
