Diode type?
Joined 2009
Please help me to find the V & A of attached photo diode.
TIA
Arrow.com lists "byp101" as a 1000V 15A 40W 80ns part from Infineon Technologies AG, and 'obsolete', with no price or availability listed.
It would be worth checking around the circuit to confirm polarity before installing it, though -- if you can get one.
Something quirky about that file PRR !
Link is here: https://dalmura.com.au/static/1-byp101.pdf
You need to go to your device supplier website and do a parametric search for something similar as an alternative, and then inspect the two datasheets to see if the alternative is acceptable.
What specs have I to check:
Forward current?
Repetitive peak reverse voltage?
Reverse recovery time?
Power dissipation?
TIA
BYP 101
Forward current 15A
Repetitive peak reverse voltage: 1000V
Forward voltage drop (25ºC 2V typ. 2.4V max.) (100ºC 1.7V typ.)
Reverse recovery time 80nS
Power dissipation 40W
STPSC15H12
Forward current 15A
Repetitive peak reverse voltage: 1200V
Forward voltage drop (25ºC 1.35V typ. 1.5V max.) (150ºC 1.75V typ. 2.25V max.)
Reverse recovery time not specified (SiC no or negligible reverse recovery)
Power dissipation not specified
On the chance that DigiKey isn't out of the question for you, try cut/pasting below into you favorite browser. They show 10 p/n's that are 1200V, 15A, TO-220, and In Stock, ranging from $1.33 to $13.99 USD, including some SiC Schottky's and even a 'FRED'. One of those ought to be a good fit.
Diodes - Rectifiers - Single | Discrete Semiconductor Products | DigiKey
Wow. Seeing it makes me wonder if it'll work, but it might save you a minute or two.
edit: Oh, good -- the website made a reasonable-looking thing out of it.
