Hi.
Im building two amps, one with Icepower 1200AS module an the other with Ncore NC122MP for my active speakers.
I saw a power (stand by) switch on Youtube that I like. Are these two amplifiers can be switched on in this way or i need any additional circuit?
In standby mode, the LED is red and green when it is turned on.
YouTube
I would like to use this button:
LB Bistable Aluminium switch with RGB light 250V O16mm Silver - Audiophonics
The Ncore NC122MP will be used in stereo and bridge (BLT) configuration.
From the picture in datasheed I do not fully understand how to connect the source to the amplifier in bridge configuration. I will use XLR input.
I would greatly appreciate your help.
YouTube
You will need additional logic to control the standby and the lamp colour.
If you are using XLR from a true balanced signal, you already have two out of phase signals which is what the amp needs...
XLR 1 --> Ground
XLR2 --> IN+
XLR3 --> IN-
Ok, if I understand correctly i connect the preamp output on one of the inputs on the amplifier and reverse pin 1 & 2 on the XLR cable?
Is it ok to turn on the Icepower and Ncore modules with just mains switch or it is better use standby option?
If anyone needs a list of basic connectors to connect an amplifiers, I've made a list of the parts needed. I need to find two more for Ncore.
housing contact
icepower AC main - JTS VHR-3N - SVH-41T-1.1
ncore AC main - JTS VHR-3N - SVH-41T-1.1
icepower OUT - JTS VHR-4N - SVH-41T-1.1
ncore OUT - JTS VHR-4N - SVH-41T-1.1
icepower IN - JTS PHR-6 - SPH-002T.5S
ncore IN
icepower LED - PHDR-14VS - SPHD-001T-P0.5
ncore LED
I still don't fully understand how to plug the Ncore inputs in bridge mode. Can anyone explain to me in a more practical way 🙂
Thanks.
housing contact
ncore IN
ncore LED
Thanks.
