I recently bought an ASUS Mini PC PN40 to replace the noisy laptop I have been using a couple of years for this purpose.
Initially I installed Ubuntu Studio as I had been using on the laptop. However I didn't like the clunky user interface of Ubuntu Studio, so I tried some other flavor of Ubuntu with a low latency kernel.
But when I got to install MPD, I found this:
I gave the alternate repository a quick try but gave up.
I started googling and found Audiophile Linux, but gave up before starting because of the low level installation.
Audiophile Linux is based on Arch Linux, so I briefly gave it a try. The Audiophile Linux installation is based on Arch installation. I have better use of my time.
I pondered using an RPM-based linux like CentOS or Suse, but I could not overcome my dislike for all things Redhat. I simply cannot forgive them for PulseAudio. I have enough of their crap at work. Vade retro satana!
I though of FreeBSD, but my experience is that they are lagging linux when it comes to driver support. My soundcard is probably not supported.
Gentoo has an old version of MPD so I had to givw it up as well.
In desperation I turned to google and realized that there are other pacman based distributions beside Arch.
I am installing Manjaro KDE and it looks very promising. As soon as I get it running I will post the recepie.
Note Debian and Ubuntu are infamous for shipping heavily outdated software. The MPD version in their respective stable releases are usually too old to be supported by this project. Ironically, the MPD version in Debian “unstable” is more stable than the version in Debian “stable”.
I use shairport-sync , but you'll need something to stream like an apple device or pulseaudio.
Good luck
Good luck
Do you want to have a headless server, or do you need a GUI based server? How do you want to „use“ your server?
BTW, I use a headless Debian server/player with MOPIDY and CamillaDSP as a convolver, based on ALSA.
If you want to go headless with MOPIDY-MPD, I can provide a „recipe“.
Kr
J
Kr
J
You don't need an x86 box. You can use a Raspberry Pi, install PiCore Player and Logitech Media Server, attach an USB HDD or network storage. You will need a a DAC hat but it works brilliantly, all controlled, including volume, from a phone or tablet.
Easier, cheaper, and, for me, better. Always on too.
Thanks for all replies. I have done some work with Raspberry Pi, I hate when the sdcard breaks.
This is a headed server (not a headless 🙂 ).
I will use MPD and cantata. There is an excellent MPD client for Kodi, I am using it on RPI for TV stuff
I know what you mean. I have been there more than once. Take a look at piCorePlayer, which avoids reading / writing to / from the SD card. It's all done in RAM, so the SD card will live "forever".
That said, MPD in Debian is fine. The term "stable" is sometimes not easy to interpret in the Linux world. Volumio and the gang are derived from Debian, and people have no issues with MPD.
How does it handle 10000+ albums? The size of my music collection drove my processor choice and i've not kept up to date since.
I don't know. Greg Erskine may know.How does it handle 10000+ albums? The size of my music collection drove my processor choice and i've not kept up to date since.
All of my, much smaller, collection of 830 albums are on FreeNAS (HP Gen8 Microserver with Xeon 1265L CPU) along with LMS and it is fine.
If you have issues with the SD card, try this with whatever you decide to use as your player...
sudo raspi-config
Advanced Options > Overlay FS
As of late, it is built into the raspi-config and easy to enable. It will ask you if you want to write-protect the /boot partition when you enable/disable the overlay, and you can actually leave the /boot partition alone as read/write and use it or link to it sparingly if you need or would like to for whatever reason. Whenever you want to change the system, just go through the same procedure to toggle it. It will appear as if it is still writeable with the overlay enabled, but upon reboot, any files you create while the overlay is enabled will be gone. I've done similar actions to make the system read only, but I am trying this out now as it stands, it's just easier to do the process this way.
S
sudo raspi-config
S
Amen to that. I use devuan on my main dev machine for the same reason. I only launch pulseaudio when i want to listen to a video using firefox. Not sure i'll forgive the mozilla team for that decision. Anyway, not quite the latest version of MPD, but close.
root@bugs:~# apt-cache show mpd
Package: mpd
Version: 0.21.5-3
Installed-Size: 2255
Maintainer: mpd maintainers <pkg-mpd-maintainers@lists.alioth.debian.org>
Architecture: amd64
Depends: <SNIP>
Pre-Depends: init-system-helpers (>= 1.54~)
Breaks: avahi-daemon (<< 0.6.31-3)
Homepage: Music Player Daemon
Built-Using: sphinx (= 1.8.4-1)
Description: Music Player Daemon
Description-md5: f318c4a927bba8215d5caa973656c5e7
Suggests: avahi-daemon, icecast2, mpd-client, pulseaudio
Tag: implemented-in::c, interface::daemon, role:😛rogram, scope::application,
uitoolkit::ncurses, use:😛laying, works-with::audio
Section: sound
Priority: optional
Filename: pool/DEBIAN/main/m/mpd/mpd_0.21.5-3_amd64.deb
MD5sum: 52f2d42864b3db780b071d5b50a1eb8a
SHA256: d7f4aeac7d1a0cafef3c7496ae93ee6d567b8060a16122a5905c99a2d4b8d03a
root@bugs:~# uname -a
Linux bugs 4.19.0-5-amd64 #1 SMP Debian 4.19.37-3 (2019-05-15) x86_64 GNU/Linux
It works just fine.
If you want a less primitive installer, try Antix (it too is systemd free) and seems to work OK on the 2 installs i've done.
Best of luck.
Like the Arch concept. Rolling upgrades. Living close to the edge.
I am almost done. I just need to figure out how to automount nfs successfully.
I use a Raspberry Pi 3B+ and an IQaudIO DAC Pro and I play music and sound tracks using a terminal although lately I had to install icewm to run VLC. Everything is saved in the SDCard. If that breaks, I have fsarchiver backups of the entire SDCard which I can restore from an external hard-disk.
Recepie
Warning, the below contains a typo. Please see post #18 for the correct text.
1. Download Manjaro-KDE full
Manjaro KDE Plasma
Choose Download button
Create a boot USB stick
2. Boot
Boot from the created USB stick
3. In Manjaro live system, connect to internet
4. Launch installation
5. Reboot
6. In you Manjaro installation, connect to internet
7. Update
Either:
"Update software installed on the system", run repeatedly until "Your system is up to date"
Or:
Start Konsole and become root:
8. Install RT-kernel
Show current kernel:
List available kernels:
Install the one named linux<version>-rt with the largest <version> :
9. Allow grub to display the new kernel
10. Reboot
11. Choose the RT-kernel in grub advanced options
12. Check running kernel
13. Check installation for some packages
14. Connect to nfs music share
Precondition is that you have set up a network server with an exported share named /mnt/music. I run FreeNAS and love it.
MPD needs these permissions, lets assign them now before mounting:
Test you nfs share:
I am using autofs because it mounts the nfs share without a hick at boot.
15. Uninstall pulseaudio
This is essential since those german bastards will overwrite your alsa configuration without blinking 😛 They invented pulse audio as revenge for you know what.😡
16. Check your soudcard
Figure out the hardware address of your card:
17. Configure Alsa
Choose your preffered card in the asound.conf, swap <card-number> for the number shown in aplay -l
18. Reboot
Maybe not necessary. The purpose was to make alsa changes stick.
19. Configure MPD
Figure out the group owning the nfs share:
Add mpd to the group owning the nfs files:
Change the MPD configuration:
20. Start cantata
Enjoy the music!
Manjaro KDE Plasma
2. Boot
5. Reboot
7. Update
Either:
Or:
Code:
$ sudo su
# pacman -Syu
Code:
$ sudo su
Code:
# mhwd-kernel -li
Currently running: 5.4.23-1-MANJARO (linux54)
The following kernels are installed in your system:
* linux54
Code:
# mhwd-kernel -l
available kernels:
* linux316
* linux414
* linux419
* linux44
* linux49
* linux54
* linux55
* linux56
* linux419-rt
* linux54-rt
Code:
# mhwd-kernel -i linux54-rt
Code:
# mkdir -p ~/backup/etc/default
# cp /etc/default/grub ~/backup/etc/default
# echo "GRUB_TIMEOUT_STYLE=menu" >> /etc/default/grub
# update-grub
10. Reboot
Code:
$ mhwd-kernel -li
Currently running: 5.4.26-rt17-MANJARO (linux54)
* linux54
* linux54-rt
Code:
$ pacman -Qe | grep -E "mpd|cantata|nfs-utils"
cantata 2.4.1-1
mpd 0.21.21-1
nfs-utils 2.4.3-2
Code:
$ sudo su
# mkdir -p /mnt/nfs/music
Code:
# chmod -R o+rX /mnt
Code:
# mount <ipaddress-of-nfs-server>:/mnt/music /mnt/nfs/music/
# mount | grep music
<ipaddress-of-nfs-server>:/mnt/music on /mnt/nfs/music type nfs (rw,relatime,vers=3,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=<ipaddress-of-nfs-server>,mountvers=3,mountport=776,mountproto=udp,local_lock=none,addr=<ipaddress-of-nfs-server>)
# ls /mnt/nfs/music/ | wc
1625 3416 23045
# umount /mnt/nfs/music/
Code:
# pacman -S autofs
# mkdir ~/backup/etc/autofs
# cp /etc/autofs/auto.master ~/backup/etc/autofs
# ls ~/backup/etc/autofs
auto.master
# echo "/mnt/nfs /etc/autofs/auto.<ipaddress-of-nfs-server> --timeout 60" >> /etc/autofs/auto.master
# echo "music -rw,soft,intr,rsize=8192,wsize=8192 192.168.72.146:/mnt/music" > /etc/autofs/auto.<ipaddress-of-nfs-server>
# systemctl start autofs
# systemctl enable autofs
1625 3416 23045
Code:
# pacman -R manjaro-pulse
# pacman -R pulseaudio-alsa
Code:
# aplay -l | grep card
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
card 1: USB [Scarlett 2i2 USB], device 0: USB Audio [USB Audio]
17. Configure Alsa
Code:
# cp /etc/asound.conf ~/backup/etc/
# cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xa1210000 irq 131
1 [USB ]: USB-Audio - Scarlett 2i2 USB
Focusrite Scarlett 2i2 USB at usb-0000:00:15.0-3, high speed
# echo "defaults.pcm.card <card-number>" > /etc/asound.conf
# echo "defaults.ctl.card <card-number>" >> /etc/asound.conf
18. Reboot
19. Configure MPD
Code:
# ls -al /mnt/nfs
total 237
drwxr-xr-x 3 root root 0 27 mar 17.48 .
drwxr-xr-x 3 root root 4096 25 mar 20.57 ..
drwxrwx--- 1627 <user> <group> 1628 6 mar 2018 music
Code:
# gpasswd -a mpd <group>
Adding user mpd to group <group>
Code:
# cp /etc/mpd.conf ~/backup/etc/
# echo 'music_directory "/mnt/nfs/music"' >> /etc/mpd.conf
# echo 'audio_output {' >> /etc/mpd.conf
# echo ' type "alsa"' >> /etc/mpd.conf
# echo '}' >> /etc/mpd.conf
# systemctl start mpd
# systemctl status mpd
# systemctl enable mpd
20. Start cantata
Enjoy the music!
Manjaro KDE Plasma
2. Boot
5. Reboot
7. Update
Either:
Or:
10. Reboot
Test you nfs share:
17. Configure Alsa
18. Reboot
19. Configure MPD
20. Start cantata
Enjoy the music!
Manjaro KDE Plasma
2. Boot
5. Reboot
7. Update
Either:
Or:
Code:
$ sudo su
# pacman -Syu
Code:
$ sudo su
Code:
# mhwd-kernel -li
* linux54
Code:
# mhwd-kernel -l
available kernels:
* linux316
* linux414
* linux419
* linux44
* linux49
* linux54
* linux55
* linux56
* linux419-rt
* linux54-rt
Code:
Code:
# update-grub
10. Reboot
Code:
$ mhwd-kernel -li
* linux54
* linux54-rt
Code:
cantata 2.4.1-1
mpd 0.21.21-1
nfs-utils 2.4.3-2
Code:
$ sudo su
Code:
Code:
1625 3416 23045
Code:
# pacman -S autofs
auto.master
# echo "music -rw,soft,intr,rsize=8192,wsize=8192 <ipaddress-of-nfs-server>:/mnt/music" > /etc/autofs/auto.<ipaddress-of-nfs-server>
1625 3416 23045
Code:
Code:
17. Configure Alsa
Code:
18. Reboot
19. Configure MPD
Code:
# ls -al /mnt/nfs
total 237
Code:
Code:
20. Start cantata
Enjoy the music!
Why the agressive tone all of sudden?
English is not my native tounge. I really like the response I got. But if we are going to get the not so nerdy out or their comfort zones using Windows or even worse Apple, we need to share our experiences.
This quote uses false logic. It also uses dramatic wording. I would not use this to make a decision on a distribution.Note Debian and Ubuntu are infamous for shipping heavily outdated software. The MPD version in their respective stable releases are usually too old to be supported by this project. Ironically, the MPD version in Debian “unstable” is more stable than the version in Debian “stable”.
- PC Based
- Building a linux based music server, decision tree and installation recepie
