Are the SB17NBAC35-8 T/S specs way off?
The German magazine Hobby Hifi measured this woofer one year ago.
Inhalt HOBBY HiFi 06/18
The results:
Re= 5,6 Ohm
Le= 0,17 mH
Fs = 29 Hz
Qms = 5,6
Qes = 0,44
Qts = 0,41
Sd = 127 qcm
VAS = 45 liters
MMS = 0,5 kg/s
Enclosure:
45 ltr. Bassreflex
Port ø 70mm, 270 mm long
- 3dB: 24 Hz
17 ltr. sealed
**** 560 mF capacitor (GHP) ****
- 3 dB: 36 Hz.
Best regards
Ludger
Was that a series capacitor?
Can this article be read online or can I order a PDF that I can translate?
Thank you,
David.
That magazine usually recommends a big value series capacitor to the woofer, to shape the low-end roll-off.
But this creates another problems as any other passive filtering around the resonances. But of course they forget to mention it. However, the negative effect is usually not negligible.
Yes. You'll get a little more group delay but if the box has a proper design, it's not a problem at all.
@ David: There are no additonal informations about the GHP-principle in the article.
Here's a post that might help you. Just put it in the deepl translator.
GHP was ist das wie funktioniert das
i did a series of quick tests for one sb17nac 4 ohm
sine -10dbfs
qts: 0.3406
qms: 6.431
qes: 0.3597
fs: 33.33 hz
sine -1dbfs
qts: 0.3362
qms: 6.732
qes: 0.3538
fs: 32.78
pink noise -12dbfs
qts: 0.3939
qms: 9.6199
qes:0.4107
fs: 38.27
mls 0dbfs
qts: 0.3806
qms: 7.5005
qes: 0.4009
fs: 36.29
