100W Ultimate Fidelity Amplifier
CA4
@apexaudio
Are STD03P/N simulation models from the simulator you use coded or publicly available? I am looking for such to LTspice.
Hi, the simulation in TinaTI was done with macros for STD03N/P modeled by me then,
they work for me adequately and the macros adhere satisfactorily to DS parameters and curves,
so that Vbe_multi with built-in ThermalTrack diodes work as expected
and express the expected Vbe_multi voltage
I added a 10R R26 series resistor with a BIAS ADJ trimpot for OPS bias
on which we can check the bias current of ThermalTrack diodes,
around about 2-3mA,
so that we can correct the flow through R8-R12 (150R + 150R) and adjust their VAS bias current sharing
MJE340 / 350 can be exchanged for any other good VAS BJTs
let's say/or similar:
1381/3503 (2SA/2SC or KSA/KSC)
https://www.digikey.si/product-detail/en/on-semiconductor/KSA1381ESTU/KSA1381ESTU-ND/1050068
https://www.digikey.si/product-detail/en/on-semiconductor/KSC3503DSTU/KSC3503DSTUFS-ND/1049721
.SUBCKT STD03N 1 2 3 4
* Model Generated by Dragan100 *
* Model generated on May 23, 2015
* MODEL FORMAT: SPICE3
* Darlington macro model with Traking diods
* External node designations
* Node 1 -> Collector
* Node 2 -> Base
* Node 3 -> Emitter
* Node 4 -> Trak
Q1 1 2 5 qmodel
Q2 1 5 3 q1model area=15.45
D1 2 4 dmodel
R1 5 3 82
.MODEL dmodel d
+IS=4.352E-9 N=1.906 BV=110 IBV=0.0001
+RS=0.6458 CJO=7.048E-13 VJ=0.668
+M=0.03 FC=0.5 TT=3.48E-9 KF=0 AF=1
.MODEL qmodel npn
+IS=2.65841e-11 BF=137.033 NF=1.05607 VAF=30
+IKF=0.152356 ISE=2.80914e-13 NE=1.34324 BR=5.15385
+NR=1.5 VAR=14.2324 IKR=0.676264 ISC=2.80914e-13
+NC=1 RB=0.101363 IRB=0.212211 RBM=0.101363
+RE=0.267757 RC=1.33878 XTB=0 XTI=3.93844 EG=1.05
+CJE=1e-11 VJE=0.75 MJE=0.33 TF=1e-09
+XTF=1 VTF=10 ITF=0.01 CJC=1.01668e-09
+VJC=0.64861 MJC=0.23 XCJC=0.9 FC=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
.MODEL q1model npn
+IS=2.56839e-13 BF=108.329 NF=0.983777 VAF=30
+IKF=0.181174 ISE=1e-16 NE=1.5137 BR=0.1
+NR=1.5 VAR=43.732 IKR=1e-05 ISC=1e-16
+NC=1 RB=4.93406 IRB=26.7409 RBM=4.93406
+RE=0.0001 RC=3.37191 XTB=0.705012 XTI=4 EG=1.206
+XTF=1 VTF=10 ITF=0.01 CJC=0
+VJC=0.635756 MJC=0.23 XCJC=0.9 FC=0.5
.ENDS STD03N
.SUBCKT STD03P 1 2 3 4
* Node 2 -> Base
* Node 3 -> Emitter
* Node 4 -> Trak
Q1 1 2 5 qmodel
D1 4 9 dmodel
D2 9 8 dmodel
D3 8 7 dmodel
D4 7 6 dmodel
D5 6 2 dmodel
R1 5 3 82
.MODEL dmodel d
+IS=82.9n RS=2.02 BV=30.0 IBV=10.0u
+ CJO=12.802E-12 M=.47462 VJ=.6915 N=1.04
+TT=4.32p XTI=2 EG=0.69
.MODEL qmodel pnp
+IS=2.65841e-11 BF=137.033 NF=1.15607 VAF=30
.MODEL q1model pnp
.ENDS STD03P
I'm assembling the ax11 layout, but I can't lower the bias that is at 330mv on resistor 0r22. I have already replaced the BC 139 and BC140 polarization transistors with MJE340 and MJE350, but it did not solve it. What can be done?
