Maybe the extra mini transients weren't handled accurately enough by a limited bandwidth reproduction chain resulting in "muddiness"
Perhaps what you perceive as "muddiness" is more accurate to the original recording than the BW limited version
The reason to add non correlating content was to mask which file it was.Cool. All other where to afraid, to old or to technically inhibited to even try. Aha so you added some fairy dust above 22 k for A and B. Thats one way to do it. Another would to leve this additions out I suppose. What made yo take this interesting path?
Thanks for your efforts! Educating.
Without, a simple spectrum analysis like the ones I have shown would have revealed all without listening.
Hans
Original was 88 as well as the posted files. No resampling dona as I understand it.
Correct. This .wav file came right from the 2L.NO site.
Hans
Correct...
...and the 'packing' of 44kHz in an 88kHz file was accomplished how, zero stuffing, duplicated samples (sorta- zero order hold), other?
EDIT: Not going to complain about however it was done, just curious. The results are not surprising to me. I have said before a lot of detail exists in 16/44. Also, it occurs to me that making all the files play at the same sample rate in the dacs takes any effect of dacs reproducing audio differently at different sample rates out of the equation.
I said go to the mat.....not Matt! 😀
But I suppose anything is possible.
I did post another option in an edit 😉 The most interesting thing is that you heard quite a dramatic difference (so you say 🙂)
Yes it’s not something I’m even slightly doubting. Like I said B and C was almost a coin flip,
but A was by far the worst of the bunch......odd indeed.
Bob, If the files were scrambled and relabeled do you think you could reliably pick out A by ear?
It could be that A is a bit muddy, but I downloaded it without any modification straight from 2L.NO.Thanks Hans,
I must say A was noticeably worse sounding.....it had a definately muddied Sound with less definition. This I do not believe to have been imagination, now the difference between B and C, I could understand as there was no night and day difference there for me....very subtle, and I could understand being mistaken.
Please don’t take this as an excuse from me but something was definitely wrong with A ?
And all I did to create B was to brick wall filter A while keeping Fs the same, just carefully doing one single step at the time nothing else.
And then C was also just one step from B by saving the 24 bit file into 16bit.
The beauty to my opininion of this sequence is that everything else remained unaffected like Level, Fs and the Dac reconstruction filter.
I could start all over again with the DXD version, downsample it to 96/24 or 192/24 and do the whole exercise again. Would this satisfy you ?
Hans
Thank you.
Not the same process at all used by DAW software to produce CD audio from higher sample rate source material. Probably explains part of why your files sound so much better than is commonly the case.
Even "better" than high-res, maybe you're on to something Hans 🙂Thank you.
Hans
Just a straight up mixed/unlabeled comparison of these three downloaded to Dropbox......I have no way to identify which ones which.
Hans,
When you say something like 24/44 is 'packed' in 24/88, exactly how does one pack it? Are the 44kHz data zero-stuffed to make them 88kHz, or what?
When Brick Wall filtering the 88.2/24 file, this was done with a fir filter working in 88.2/32 float for optimal accuracy, the result stored again in 88.2/24.
No zero stuffing or anything like.
Hans
Matt might be right, maybe your on to something Hans..... I just did another comparison between A and B , again preferring B
Could also be I’m just so used to sub par I actually prefer it!
Ha, ha, the only thing I was on to was to find out whether perceived differences have anything to do with other factors as level, upsampling filters, reconstruction filters or whatever that can manipulate the signal in the reproduction chain.
All these variables have been excluded in this test.
Hans
If we're discussing old tape formats, does anybody have a secret magic pinky finger never tell fix for the Revox A-700 meter's sticking? Mine runs fine but the (insert profanity here) meter sticks mechanically. Have tried everything obvious, no joy.
Also, if anyone wants a Sony TC-765 and/or a lot of Teac parts, they're yours. Now decades old, but free of course.
All good fortune,
Chris
Loosen the jewel against the rotating vane pressure.
-RNM
Hello Hans,
I listened to your test files in two sessions, and I wasn't able to tell them apart, i.e. they sound the same to me.
At moments, I thought to have heard slight differences, but I could not confirm them in close hearing.
The equipment used was Oppo105D, Bruno's preamp from Linear Audio Vol. 5, and the "Crocodile 2" driving a pair of Sennheiser HD580 headphones.
So now I know not to belong to the "Golden ears" community🙄
Regrads,
Braca
Might try it again on a better CD player. I also bought the top OPPO thinking it would be my last CD player. But it sounded so bad and I could do nothing that improved it at all. (jitter?) I didnt even try to sell it... was new .. just gave it away, as i was so disgusted with it.
THx-RNMarsh
Thanks Hans,
yep. Sounded that way to me also.
'A' was way bad. Obvious with my computer dac and old ears and ear buds.
So, it had to be really bad to sound so much worse than B and C.
Might recheck what was done on that A file?
THx-RNMarsh
- Member Areas
- The Lounge
- The Black Hole......
