If it's purely an engineering challenge why bother designing yet another DAC?
Understood.
Hypothetically, if such properties did exist what would you accept as evidence of it?
Also, in the context of responding to the above question please clarify what you mean by the term 'measurable.' Measurable by an AP, theoretically measurable, something else?
Double blind peer-reviewed study with a large sample size. What would pass for other sciences.
Demonstrably measurable is how I would respond to your second question - something that can be put on paper. I'm fine with coming up with a test or measurement as long as it is done correctly.
We should probably agree to end this line of discussion or move it to another thread, though, since it's got nothing to do with AK4499.
When discussing anything like this I feel that everything should be kept solely to technical details and that any subjective impressions be left out.
Regardless of anyone's reputation subjective impressions are pretty much meaningless. Especially for devices which have already pushed the nonlinearities so far below the threshold of audibility. For loudspeakers it's slightly different as the way they react with the room is of vital importance and a subjective impression can be useful, but not for DACs.
It's enough to say I heard both and preferred A over B, that's fine. And then leave it at that. But when you say A was significantly better than B when both are essentially transparent...there's no way that A was significantly better than B. Was A playing undistorted music with an excellent level of fidelity? Yes? Was B? Yes? Then they were at worst very similar or at best actually identical.
For there to be an actual significant difference one would have to be broken. Night and day differences require one to be playing the song backwards or for one to be twice as loud as the other. When comparing devices as good as this there is no significantly better than the other. Hell the two might not have even been level matched. This sounds like a very casual setting so they probably were not.
There's significantly better in my head mind you. I prefer the sound of B because it's built in the way I like the idea of.
When discussing something in a thread like this we should keep the discussion technical because these are merits that are common to all devices, for direct comparison, and common to us in that we all understand what specifications mean.
If one device has oversampling of 256 instead of 128 then great. Explain why this has the potential to sound better.
I for one appreciate the fact that the digital filters in the AK4191 actually have as much stopband attenuation as the noise floor so that absolutely nothing will alias through. I don't consider one with only 100dB sufficient in a product with a noise floor way below this, such as in the AK4499. Now of course I doubt I'll hear it but it is technically superior in one respect.
I 100% agree.
Understood.
Mathematically, a "measure" on a set is a systematic way to assign a number to each suitable subset of that set, intuitively interpreted as its size (see Wiki for more).
The immediate result is that "measure" has two preconditions: a) define the subset (for example, "the currents"), and b) define a "metric" (for example the Ampere). There are some mathematical constraints in choosing these, out of which the metric injectivity is essential.
By the very nature, listening reports are not injective functions, because they don't conform to the "measurement" requirements. As a result, the whole metric spaces theory doesn't apply, in particular the additivity property. Which means that you can no longer claim that changing a capacitor changes the sound for better (or worse), or that using a LDO instead of a 7805 worsens the sound, without exposing yourself to ridicule, at least from those who know what they are talking about. Which are in fact never the message target when stating such logical nonsense, so you are safe to carry on.
...in the context of responding to the above question please clarify what you mean by the term 'measurable.' Measurable by an AP, theoretically measurable, something else?
Hilarious, but not an answer to the question of what Chris719 meant (intended) by his use of the term 'measurable.'
I thought I defined the concept of "measurable" pretty good, perhaps you are missing the Lebesgue measure definition, or it's extension (Borel measure definition) on topological spaces? I can help with that, otherwise, once again, I am happy for you feeling entertained.
I thought I defined the concept of "measurable" pretty good...
Of course you thought so, since it reached the conclusion you wanted. Another case of confusing physical reality with mathematical models. No need to bother with that and no need for me to ask you since you have already made quite clear what you believe about the value of listening. Unless of course, you now want to agree that listening has value for usefully judging audio design performance?
Very succinctly put. :up: Good for future reference.
I wish everything didn't have to turn into a holy war here, but it is what it is. Maybe the forum would be better off with a section where there are no subjective impressions discussed in threads, and another where there are. I don't know. Even though many of us (including myself) have been involved in taking threads in these directions, it gets old seeing the same arguments pop up on page 20 of any technical discussion.
What would it take to lift the fatwa on subjective impressions d'ya think?
I'd say (FWIW) the OP might do well to indicate whether subjective impressions are unwelcome - the default being they're OK since this is a hobbyist site, not HA.
I'm not sure. It would help if people wouldn't promote their subjective experiences as accepted fact.
Just because it's a hobbyist site doesn't mean the format couldn't change a little or additional sub-forums be created. It's not gonna happen here, I know that.
This was a technical discussion? Give me a break.
JohnW related an anecdote about what he had the opportunity to listen to, and suggested that if the announced production pieces sounded as good as what he heard, he'd guess that it might be a great combination. You and others jumped on him and demanded that he justify, what, his experience?
This thread should have been moved to the lounge days ago.
There needs to be qualifiers with subjective experiences with zero evidence because this forum is filled with BS.
I asked him a simple question. You know he thinks he has the "secret sauce". He's not the only one here who thinks that way.
Qualify your statement or be prepared to put up. If you want to push the idea that, as an example, close-in phase noise is the secret of audio reproduction quality, then either drop the certitude or be prepared to give real data. You know how many people there are here with different subjective opinions they push as gospel? Lots. I was just told not long ago that this DAC is 100% certainly crap anyway because it's not R-2R.
Fine as a concept but the 'objective' side do not practice this any more than the subjectivists do. I asked @Naaling for evidence of his claim that subjectivists expect objectivists to believe them at face value. None has been forthcoming so far so I take it there is none. So all the preaching about 'back up claims with evidence' is hollow.
Those who make the claims need to bring the evidence. This is how the rest of the world works. I'm not sure why so many people here don't understand that you can't prove nonexistence without being all-knowing. I don't know Naaling or anyone else you want to lump me in with on this thread, either.
