First port of call is always tubedata.info where the datasheet was located
http://www.frank.mif.pg.gda.pl/other/ServiceTypes/cv4-2/CV2231.pdf
No curves , you will have to plot these yourself if you have the valves in your possession
316a
316a
Thank you very much for your answer. Oh sure. I was there first. I was offered a lot of these lamps at a low cost, so I decide whether to buy or not. I don’t have a tracer, and drawing curves by hand for a very long time.
I have never seen one of these valves in over 20 years collecting . Ask for a sample from the supplier , test it and plot the curves . There is probably a very good reason why there were a lot of these going cheap
316a
- Tubes / Valves
- CV2231 (A2266, E2266)
