TacT Millennium Amplifier MK2
Hi
I have recently acquired a TacT MK2 Millennium Amplifier.
Unfortunately, it's a missing the remote control and I would really like to utilise the "max volume" and "display dim" features. There is no menu system to set this using the fascia buttons. I have a Lyngdorf branded multi remote, and unfortunately it does not control it.
It's a very old model now, so the chances of finding one second hand are slim... The max volume feature is of particular importance to me as it stops (little) people turning it up too loud if they play with the free spinning wheel. It's saved my speakers from excess volume / damage many a times when using a Lyngdorf model with this feature.
Are any former/current owners out there able to assist? I have a programmable IR blaster to hand, or failing that perhaps utilising the on board RS232 interface a possibility?
Thanks very much,
Dawson
Usually these electronic´s designer have not invented their own IR-code for the remote of a low volume product.
There are quite some basic languages and one of these will be spoken by your amp.
Take yourself some time and (maybe an older) well functioning universal remote. Read the manual. These remotes all have some kind of search mode.
It can take quite a few hundred "tip/tap" until the amp responds for the first time.
Then you can figure out which code it is. In the search mode you can "blink out" the name/model of the working code and then find the complete IR-code that is used on the internet. You are not the first person running into this problem...
This is quite a nerve consuming work, but in the end you can usually store a complete set into a learning remote, if the commands do not match a pre defined pattern.
Be sure to document once you have the code, sometimes changing batteries erases a remote.
Would be nice to have an app doing this work in an automated way. Older laptops all had this IR sender/ detector integrated to communicate with (at that time) smart phones.
Thanks for the link. Unfortunately I can't get this CFF file to convert, but CFF extractor is able to allow me to view the codes.
My objective is to convert this file into a format that my Android phone can understand, and utilise my Galaxy S5's IR Blaster capability.
The raw values of the CCF are as follows:
LEFT
0000 006B 0026 0000 0152 00AD 0016 0041 0016 0040 0016 0041 0016 0015 0016 0016 0016 0015 0016 0016 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0040 0016 0041 0016 0041 0016 0015 0016 0016 0016 0015 0016 0041 0016 0041 0016 0016 0016 0015 0016 0016 0016 0041 0016 0041 0016 0041 0016 0015 0016 0016 0016 0041 0016 0040 0016 0041 0016 0015 0016 05D7 015B 0056 0016 0E78 015B 0056 0016 00AD
RIGHT
0000 006B 0028 0000 0158 00AD 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0016 0016 0041 0016 0015 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0040 0016 0015 0016 0016 0016 0015 0016 0016 0016 0040 0016 0015 0016 0016 0016 0015 0016 0040 0016 0041 0016 0040 0016 0041 0016 0016 0016 0041 0016 0040 0016 0041 0016 0015 0016 05D7 015B 0056 0016 0E79 015B 0056 0016 0E79 015B 0056 0016 00AD
VOL DOWN
0000 006B 0026 0000 014C 00AD 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0016 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0040 0016 0015 0017 0015 0016 0015 0016 0041 0016 0040 0016 0015 0016 0015 0016 0015 0016 0040 0016 0041 0016 0040 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0017 05D6 015B 0056 0016 0E78 015B 0056 0016 00AD
VOL UP
0000 006B 0026 0000 0156 00AD 0016 0040 0016 0041 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0040 0017 0040 0016 0041 0016 0040 0016 0041 0016 0015 0016 0016 0016 0015 0016 0015 0017 0040 0017 0014 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0040 0016 0015 0016 0041 0016 0041 0016 0041 0016 0015 0016 05D7 015B 0056 0016 0E79 015B 0056 0017 00AD
CHAN DOWN
0000 006B 0026 0000 0159 00AD 0017 0040 0017 0040 0016 0041 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0016 0016 0040 0016 0041 0016 0041 0016 0041 0017 0040 0016 0015 0016 0041 0016 0015 0017 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0040 0016 0041 0017 0040 0016 0041 0016 0015 0016 05D7 015B 0056 0016 0E78 015B 0056 0017 00AD
CHAN UP
0000 006B 0026 0000 014D 00AD 0017 0040 0016 0041 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0017 0014 0016 0015 0017 003F 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0041 0016 0015 0017 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0017 0040 0017 0040 0016 0040 0016 0041 0016 0015 0016 05D7 015B 0056 0016 0E79 015B 0056 0017 00AD
MUTE
0000 006B 0026 0000 0158 00AD 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0016 0016 0015 0016 0041 0016 0015 0016 0015 0016 0040 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 0015 0016 0040 0017 0015 0016 0040 0016 0016 0016 0015 0016 0040 0016 0041 0016 0041 0016 0016 0016 0040 0017 0014 0016 0041 0016 0040 0016 0015 0017 05D6 015B 0056 0016 0E79 015B 0056 0016 00AD
0000 006B 0026 0000 014D 00AD 0016 0041 0016 0041 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0017 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0015 0016 0041 0016 0040 0016 0041 0016 0041 0016 0015 0016 0040 0016 0041 0016 0040 0016 0015 0016 05D6 015B 0056 0016 0E79 015B 0056 0016 00AD
0000 006B 0026 0000 014E 00AE 0016 0041 0016 0041 0016 0040 0016 0016 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0040 0016 0041 0016 0041 0016 0016 0016 0015 0016 0015 0016 0041 0016 0041 0016 0015 0016 0016 0016 0015 0016 0041 0016 0040 0016 0041 0016 0015 0016 0015 0016 0041 0016 0040 0016 0041 0016 0016 0016 05D6 015B 0056 0016 0E78 015B 0056 0016 00AE
POWER
0000 006B 0026 0000 015E 00AD 0016 0041 0016 0040 0016 0041 0016 0015 0016 0015 0016 0015 0016 0016 0016 0041 0016 0015 0016 0016 0016 0041 0016 0041 0016 0040 0016 0041 0016 0041 0016 0015 0016 0016 0016 0015 0016 0015 0016 0015 0016 0016 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0040 0016 0041 0016 0041 0016 0040 0016 0015 0016 05D7 015B 0056 0016 0E79 015B 0056 0016 00AD
X
0000 006B 0026 0000 0158 00AE 0016 0041 0016 0041 0016 0041 0016 0016 0016 0015 0016 0016 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0040 0016 0041 0016 0041 0016 0040 0016 0016 0016 0015 0016 0015 0016 0041 0016 0015 0016 0041 0016 0015 0016 0015 0016 0041 0016 0041 0016 0041 0016 0016 0016 0041 0016 0015 0016 0040 0016 0041 0016 0015 0016 05D6 015B 0056 0016 0E79 015B 0056 0016 00AE
POLARITY
0000 006B 0026 0000 0155 00AD 0016 0041 0016 0041 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0041 0016 0015 0016 0015 0017 0040 0017 0040 0017 0040 0016 0040 0016 0040 0017 0015 0016 0015 0017 0040 0017 0014 0016 0015 0017 0014 0016 0015 0016 0040 0016 0041 0017 0040 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0015 0016 05D7 015B 0056 0017 0E78 015B 0056 0016 00AD
MAX VOL
0000 012E 0026 0000 0150 003D 0016 0016 0016 0016 0016 0016 0016 0007 0016 0007 0016 0007 0016 0007 0016 0016 0016 0007 0016 0007 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0007 0016 0007 0016 0007 0016 0007 0016 0007 0016 0007 0016 0007 0016 0016 0016 0016 0017 0016 0016 0016 0016 0016 0017 0016 0016 0016 0017 0016 0016 0007 0016 0007 0016 0211 015B 001E 0016 0520 015B 001E 0016 003D
DISP LIGHT
0000 006B 0026 0000 0154 00AD 0016 0041 0016 0040 0016 0041 0016 0016 0016 0015 0016 0016 0016 0015 0016 0040 0016 0016 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0040 0016 0015 0016 0015 0016 0015 0016 0016 0016 0015 0016 0041 0016 0040 0016 0016 0016 0040 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 0016 0016 05D6 015B 0056 0016 0E78 015B 0056 0016 00AD
CHNG DIGI
0000 006B 0026 0000 0152 00AD 0016 0041 0016 0041 0016 0040 0017 0014 0016 0015 0016 0015 0016 0015 0016 0041 0016 0016 0016 0015 0016 0040 0016 0041 0016 0041 0016 0040 0017 0040 0016 0015 0016 0041 0016 0015 0017 0040 0016 0015 0016 0015 0017 0015 0016 0015 0017 0040 0016 0015 0016 0041 0016 0015 0016 0041 0016 0041 0016 0041 0016 0041 0016 0015 0016 05D7 015B 0056 0016 0E79 015B 0056 0017 00AD
Any assistance would be greatly appreciated!
Ah, excellent - that's worked a treat! I was trying to import the CFF directly into irplus but it wouldn't accept it... The XML conversion has gone through and the amp is responding as expected.
I am amazed by how much knowledge and programs are out there regarding remote control... It's a bit of mindfield and you've been a great help, thank you 🙂
P.S PM me your paypal addy adelias, I owe you a pint for that.
Resurrecting an old thread. I want to convert all my remotes to a single programmeable one, and I found this: http://www.keuwl.com/apps/049remotecreator/ IR remote creator.
Extremely flexible, in addition to using codes from an online database and a 'learning' mode, you can even enter the actual raw codes.
Includes a nifty way to layout your own 'remote control' screen and customize and name buttons. A dream!
It is an android app, but of course your phone or tablet needs an IR blaster. I have an 8 year old Samsung SM-T800 which has an IR blaster on the side, but it doesn't work with IR creator. Funny enough, I downloaded an other app and it worked with that ...
But it's a bit unwieldy and the IR on the side is awkward to point.
Since the latest phones no longer sport an IR blaster, what would be a cheap older phone that has one, anybody has any tips?
Jan
