I will make 40cm wide, and taller.Tganks, and yes, they are exterior
Many thank
Here is a link to my build. Still working on it. I need to seal the top, bottom and the front with Baltic Birchwood like the sides and back. The front mount that you see is cheap plywood Im using to test how many ports I want. Enjoy the music. ps it sounds much better in person. YouTube
New week I'll post my speakers playing the theme song for Schindler's List composed by a John Williams. FYI, this is not for the weak at heart. It sounds amazing on my speakers. YouTube
Hi Alex, doesn't look like a Fane wideband, what driver is that?
Hi Sebastian, that a Lii Audio Fast 10. Bout it for $450.
I know Steve Creswell did some more detailed posting on his build with these on audio talk forums, but since they are currently throwing errors when I try to signup I wonder if he might elaborate a bit on the details of the resistive vent/brace development (I don’t think he explained this here). Specifically, I wonder about the type of material that he attached to the internal brace, and details on stuffing on the lower part. I have some denim felt (about 1 cm and a bit thick) I wonder if would work for either they application?
Best seller in Europe is Blue Aran Blue Aran - The UK's no.1 Loudspeaker Component Stockist
I always use them and get a great deal and good service.
CPC will have some in on the 11th November.
https://cpc.farnell.com/fane/sovereign-12-250tc/full-range-driver-12-250w-rms/dp/LS04398
Blue Aran are the main UK official Fane distributor, it's a very tough time for pro sound oriented companies right now so if possible please support them when you can.
Fane will be awaiting the next delivery themseves then they will be available for sale from both CPC and Blue Aran.
Fane is based in the UK, and as the pandemic hits hard there. There are all kind of measures to contain the pandemic and many companies are closed or working with less people. And a part of the production happens in India, a country that is also heavy infected by covid. wich also will have an impact.
It's not only Fane that is affected, Mark Audio also had stock issues a few months ago. Idem with 18sound i heared from insiders in the company. They mostly could keep up with the demand with emptying their backstock, but on some places the stock ran out.
- Full Range
- New 12" Full-Range: Fane 12-250TC
