Please excuse this newbie question. I am have been doing lots of reading on this forum and would like to try my luck and build my first diy pair or speakers. I just want something simple (no crossovers etc). From what I understand, smaller drivers are better at the higher end and larger drivers better at the lower etc.
So for example, the FE103en would lack some bass and the FE206en would lack some treble. Would it be possible to have one speaker of each, the 103 on the left and the 206 on the right and perhaps they would compensate and compliment each other.
Or is this a bad idea and it would sound horrible, and I am the person that should forget all this and just buy commercial speakers.
Many thanks.
Many thanks.
If you mean having a different driver play the LH stereo chanel than the one which plays the RH channel, then that would be a bad idea sound balance wise.Would it be possible to have one speaker of each, the 103 on the left and the 206 on the right and perhaps they would compensate and compliment each other.
The drivers must be identical on both stereo channels.
For clarity, I've provided links to the drivers:
https://www.fostexinternational.com/docs/speaker_components/pdf/FE103En.pdf
https://www.fostexinternational.com/docs/speaker_components/pdf/FE206En.pdf
As a self-confessed newbie, do you realise that Fostex drivers are quite unique and require sophisticated back loaded horn enclosures the give of their best?
I would look for a more newbie friendly driver and I'm sure members here can give a suitable suggestion.
Galu, you are right...I think I misunderstood yatr98. I thought he is talking about WAW (wideband assisted with woofer), two speakers per side.
Off course, different speakers for left and right channel is not acceptable.
Otherwise here is nice setup by X.
10F/8424 & RS225-8 FAST / WAW Ref Monitor
Hi adason!
The OP was asking for something simple i.e. a single full range driver with no crossover.
Do you know a good candidate, bearing in mind that I suspect that a simple cabinet construction would also be in order?
A Fane 12-250TC would be my choice SJ, but it's a bit of a step up from the 4" and 8" drivers that yatr98 was considering.
@yatr98 - Please give us some information about your intended use for the speakers and how large an enclosure you can accommodate.
Hi Galu,
My intended use is very basic, CDs/vinyl. My room is 14 x 14'. I was looking into BR to start and would eventually like to try FH mk3 since I hear so many good things. I was interested in the Fostex FE126en...something that is in the middle of the line maybe can deliver a little of both? But I ask myself, will there be enough base, will there be enough high end? I am not a super audiophile so I am not that picky and my expectations are low.
Also, you are right, I was asking about different drivers on the LH and RH. But I guess that is a bad idea.
I agree with the consensus that different drivers on the left and right is a terrible idea.
Comparing the 206 and 103, the 206 gives up nothing to the 103 on the high frequency end, so if you want a 206 just get one and forget the 103. On the other hand, larger FR drivers tend to "beam" more, creating a smaller "sweet spot" in the room. Also, I agree that Fostex drivers are best in back-loaded horns and other enclosures that make the most of them.
One of the simplest builds that would be very satisfying and very doable would be to buy a pair of 6" (ish) Mark Audio drivers (Alpair 10.3, Alpair 10P, etc.) and put them in "Pensil" enclosures. Extremely simple build. They will sound far better than you could imagine for the amount of money and time invested. Heck, even a pair of 4" drivers like the Alpair 7.3 or CHR-70 will surprise the heck out of you. Put them in a box of your choice and enjoy. Frugal-phile | Box Library / Mark Audio (Focus on the "Mark Audio Pensil Series" and "ML-TLs" in that list - they are the easiest to build.)
Don't overthink it.
After you get those under your belt and enjoy them for a while, you may stop there or you may decide to explore further.
Don't overthink it.
Good advice from cogitech - just a few words to aid your understanding re bass/treble reproduction:But I ask myself, will there be enough base, will there be enough high end?
To ensure maximum bass, go for the largest diameter speaker.
The high frequencies are basically handled by the central portion of the cone so they are taken care of regardless of the overall diameter of the cone.
https://www.fostexinternational.com/docs/speaker_components/pdf/FE126En.pdf
Also, keep in mind that a good box can go a long, long way to producing bass out of a very small driver.
Here is a pair of 3" drivers filling a bedroom with ample bass. No, there is no sub hidden here. $8 drivers and $30 worth of ply wood. The weakest link is the crappy Chinese amp (which is now in the rubbish bin). This was a "proof of concept" build to see how cheap I could really go.
If you take my advice above, it'll sound WAY better than what you hear in this video. Clicky linky.
YouTube
And yes, larger drivers will (generally, by their very nature) provide more bass, but don't underestimate 4"-6" drivers (especially from Mark Audio, IMO) and also keep in mind that an 8" FR driver will typically beam like a MOFO.
YouTube
Yes, the Mark Audio make up for lack of size in larger excursion, I have Jordan Eikonas and they are similar, far more bass than the Fostex FE126
Thank you Galu and cogitech for your advice. I will not overthink and just try something simple. I am sure they will just fine.
These sound great cogitech.
Have you ever published the enclosure plans?
Yes, somewhere around here.... BRB.
EDIT: Yep, found it ... (I paid $10 for each driver... must have been $8 USD at the time).
"nanoTower" - Tang Band W3-881SI
Plenty of support around here if you have questions along the way. Avoiding the paralysis by analysis is a good thing, but a measure of restraint is also in order. There is such a thing as rushing too much, too.
If this your first system and you are smart enough not to complicate things, then the 103 or other 4" FR driver can be very rewarding in a 32" foam board Cornu.
Ever think of building a Cornu Spiral horn? Now you can!
I still need to build me some Cornu speakers...
Maybe post some links for the OP so he can see if they appeal to him?
I am currently chair bound and unable to get to the computer, just the iPad at hand but I gave the link for the thread.
Sorry to hear that, Cal. Hope you feel better soon.
- Full Range
- Completely Stupid question about drivers
