John Curl's Blowtorch preamplifier part IV
I don't have time to explain the obvious in every post that someone otherwise might misconstrue.
Good that you have enough time to spread BS about the superior sound of the 7805 regulator and how painting the inside of a DAC improves the sound. You are very efficient, no question. Good luck with setting up a test valid for 7.5 billion people.
what's wrong with the old 7805?
Nothing, it's only noisy as hell, has a crap frequency response, and needs precautions (at the output) to keep it stable. Otherwise, some claim it has special unknown/unmeasurable properties that makes it sound better than a modern LDO regulator when used in a certain DAC model power supply. This conclusion was reached by uncontrolled listening tests and is now considered a "secret sauce" for designing a good DAC.
Quotes available upon request. Which doesn't mean a modern LDO sounds better in that position, only that "if the regulator static and dynamic parameters matter, then a 7805 has absolutely no reason to sound better".
The fact remains some people hear it.
In what setting? This is something you've been keeping hidden. Wonder why.
Say you measure hearing ability of 300 people, they are a sample of 300 out of a population of 7.5 billion. What are the chances of randomly selecting 300 test subjects, and having them not be very statistically representative? The chances are extremely high they will not be very representative. (Not to mention the chances you will not correctly measure what you are trying to measure, you may actually be measuring more of something else like the false negative chances of ABX DBT.)
Those who shill for audio business tend to use the same playbook.
"That´s all" it should be that simple but as history and todays discussions imo show, it is not, as the guard against false negatives is routinely neglected.
I became member of the AES and therefore read some time later the first article by Les Leventhal about the potentially high probability for false negatives when using the then often used ABX tests. New stuff for me (nothing new in the other fields but in these often neglected even up to today) and it became clear that some modifications of the test routine were needed.
Here is the magnitude of the two signal envelopes and the difference in red. The Gibbs effect is obvious in the filtered signal but there are differences that are clearly at frequencies well below this.
