Victor,
Just for curiosity's sake - do you know what kind of changes were made in the latest version of the OPT compared to the previous version(s)?
Looks like the PC boards on the sides of the transformers are missing on the C version. Will they be shipped with the upgrade package?
Mr Fujita tests the OPT without the PCB Board
The C version will come with PCB board and HV connectors.
I need Mr Fujita to design the PCB board for me.
Also Lundhal will be available in the 2nd week of February..
Victor,
The C version is the new design from Lundhal. According to Mr Fujita , the C version's sound quality is very good.
Using the TU-8800 as power amp
Hello,
I am thinking abut purchasing the TU-8080, but I own a good digital preamp-DAC which would like to use as preamp.
Is it possible to identify the "pre-in" of the amp so I could wire inputs to that point the case? Or is it OK to just raise the volume of the TU-8080 to some point and leave it there and just connect the preamp to one of its inputs?
Thanks,
M
Hello,
Thanks,
M
Using KT-150 tubes
And another quick question.
Do I understand correctly, that while it is possible to use KT-150 tubes in high-mode, this is about compatibility only, there will not be more output power, correct?
In my experience big tubes, KT120 and KT150, aren't used to their full advantage in an amp that doesn't bias them "hot" enough to get into their sweet spot. You might get better sound using a mid-power tube, KT77 or maybe an EL34, and save a bunch of money that you could put towards a Lundahl upgrade. 🙂
You might get slightly more power out of the "Big" tubes but not enough to make a significant difference.
My favourite tube by a long shot is the Gold Lion (Russian reissue) KT77.
Steve
Steve
Victor,
How does the TU-8800 sound compared ro TU-8600, both with Lundahl?
Can any of these amplifiers, base model, be upgraded later with Lindahl?
Thank you,
Robert Lachance
rlachance13@gmail.com
Thank you,
Robert Lachance
Am also in agreement (in my CJ & Cary amps). Some magic in the GL KT77s.My favourite tube by a long shot is the Gold Lion (Russian reissue) KT77.
Steve
It is not just your experience, it has technical reasons. Oversized tubes work in a less linear region of their characteristics so that the distortion will be higher at the same output power. KT120 and KT150 are less linear than smaller power tubes anyway as there are artifacts in their transfer curves.
The TU-8800 has 3 power settings, the EL34 and 6L6GC fall into the medium category. I am a bit surprised though why KT66 and KT77 are classified as high power tubes. Their limiting values are very close to those of EL34 and in case of KT66, the max. plate voltage is even lower.
I made a calculation for TU-8200 some time ago. There is negligible difference between 6L6GC, EL34 and KT88 in that amp in pentode mode in terms of maximum power even though the KT88 is able to provide about 40% higher output power than the other two if biased accordingly.
If I understand correctly, the TU-8800 does auto-bias. What is changed by the high-mid-low setting? Bias level? B+ voltage?
After reasing a lot the past days about how tubes work only correctly "in their setup" (meaning correct B+, bias etc.), I am wondering, if the configuration in the TU-8800 is only "making other tubes" to produce sound (ok, purposedly being a little polemic here) with the high-mid-low.
Or if per setting there is one tube type only, which is ideal.
Or if the only ideal setup is only high with KT-88 (or why is it printed in bold?).
Can any expert shed some light here?
It is hard to say anything without seeing the schematics, but I am sure the B+ is different in these settings, and quiescent current is hopefully different as well.
ERYN's TU-8800
Hi Victor,
I would like to let you know my TU-8800 has finally finished. I did a few changes and it's really good (attached some pics for you):
- painted the chassis graphite black,
- replace the switch button extension rod with a carbon fiber one,
- use my favorite Nichicon lytic caps instead of the stock caps except the United Chemi-Con C114, C214,
- use Nichicon SEPC low ESR caps instead of the stock caps
Tubes I use KT88 and NOS ECC81, I've checked the voltage check points and they are quite close to the reference ones. I tested with my headphones and it sounds really good, should be even better after it burn-in for some time. It sounds quite different from the TU-8600. I think with the Lundahl opt will be even better.
Thanks!
Eryn
Hi Victor,
Thanks!
Eryn
I have an 8800 as well, with telefunken pre's and tung-sol kt120 output tubes. wiring is stock, but I have ordered upgrades.
what does the 8600 sound like, in contrast?
