Just a few basic q's re a crossover re-build fo type type LSU/HF/III.LZ/8;
I've opened them up and the 3.3uF capacitor & 0.5mH inductor on the HF output are in the opposite positions to those indicated on the schematic below - is this likely to be a mistake?
Or does it not matter for these components?
I've seen 2 versions of schematics for the 12/15" models that show both arrangements.
Also, I need an 8uF capacitor for the HF input (nearest is 8.2); would a 3.3uF & 4.7uF in parallel suffice?
Finally, can anyone recommend a good type of capacitor to use? - I don't want to let these speakers down but I don't want to break the bank either.
I've seen Jantzen Superior-Z recommended, but that will come to over £300...
Doesn't matter, they are still in series. Either way is fine.
Yes, certainly, as long as they are nonpolar or bipolar types.
Thanks Rayma
