BC550/560
I bought some C-grade (highest beta) BC550's and BC560's from Rochester. The price was extremely low, BUT Rochester has a $250 minimum per line-item. I swallowed hard and bought $250 worth of BC550C's and another $250 worth of BC560C's. I'm now set for a good many months.
attachment.php
_
Update:
Both Mouser nor Digikey list BC560s as obsolete and neither has stock as far as I can tell.
Rochester has plenty, in a variety of grades, but the min buy is $250 (~2000 pcs) for the most expensive (BC560CG by OnSemi)
Anyone interesting in splitting an order with me?
Kind regards,
Drew
Some enterprising person needs to make micro-breakout boards for a couple of BC850 or BC860's - connected with emitter resistors a pair of the SOT23's will have comparable dissipation rating and noise performance I reckon.
Farnell quote BC560 as no longer manufactured, as is the BC179, but the NPN ones (BC550's and BC109C's) are available (109C is "best seller")...
I was lucky enough to foresee this ahead of time -- and I bought 1000 of each so I'd have plenty of BC550-560 parts to mess around with, enough for the rest of my life.
I'm glad I did.
Maybe you, dear reader, might want to imagine the delisting of your favorite through hole devices ... and then immediately buy a lifetime supply now. I suspect you'll be glad you did.
The wafer appears to have moved to India. CDIL is now producing the BC560-TO92. I can not say if the quality is right. It's a shame how the good parts disappear just because they're not SMDs.
