****SOLD to Greg****
I have the following parts for sale (TAKE IT ALL PRICE NOW $159 USD with FREE Shipping to Lower 48 & Canada) :
THIS IS THE DEFINITIVE LIST FOR THE LOT
6 Elna Silmic II Polarized Capacitors (4-47uF 50V/2-1000uF 16V)
5 Nichicon KA 105C Audio (3-4700uF 16V/1-220uF 25V/1-47uF 16V)
24 Nichicon Non-Polarized MUSE (2-220uF 25V/8-220uF 16V/6-47uF 25V/4-47uF 16V/4-4.7uF 50V)
1 Nichicon Fine Gold 220uF 10V
3 Nichicon UPW 105C Low Impedance-Long Life Polarized Caps (3-470uF 16V)
1 Panasonic (Mashusita) 100uF 25V NP Cap.
2 MPSU57 Transistors
15 Small Anti-Static bags
1 35Amp 800V Hi-Power Diode Bridge
10 2Amp 800V small Diode Bridge
2 Positive Regulator (317 Type)
2 Negative Regulator (337 Type)
5 Misc Small Heatsinks
LOT of >100 Fuses - Various Ratings
Lot >100 3/16" & 1/4" Male (Blade) Circuit Board Terminals
4 DIY 3' long Alligator Clip to Aligator Clip cables
10 NEW Alligator Clips New in Bag
2 4" Banana Jumpers
2 Solen Crossover Board Stereo Connector
7 Dual Banana Plugs (Red)
4 Single Heavy Duty Banana Plugs
40 5-Way Binding Posts
8 Other 5-Way Binding Posts (White/Red/Black)
24 Nakamichi Banana Plugs (Mostly NEW/a few Mint)
NEWLY ADDED**** 2 - MINT 6 ft Audioquest VDM-X Digital Coaxial Cable with Silver-plated Conductor/Shield with RCA to RCA connections
NEWLY ADDED 1 - NEW 5ft Blue Jean Cable Digital Cable- Belden 1694A cable/Canare True 75ohm RCA and BNC Hybrid Cable (BNC to RCA Cable)
1 20Ft Balanced XLR(M) to XLR(F) Shielded Microphone Cable
1 50FT Balanced XLR(M) to XLR(F) Shielded Microphone Cable
1 6FT 1/4" to XLR(F) Shielded Microphone Cable
1 3Ft 1/4" to 1/4" Microphone/Pro Shielded Cable
1 20 Ft Single RCA to RCA shielded Video Cable with quality RCA's
1 Pair NEW 2' Redco Mogami 2524/Neutrix Analog Cable Balanced to SE cables $25USD/pair
2 6FT BNC to BNC Shielded Hi-Quality Digital/Video Interconnect
1 3' BNC to RCA Shielded Adapter Cable
3 Hospital Grade 3' 3X16AWG Power Cord with IEC connector IEC C13/5-15P
1 Power Cord - Shielded cable + Ferrite Core/Copper shielding (DIY Cable) with IEC C13/5-15P
1 Power Cord 2 Pole 5' IEC Connector (No ground pin) IEC C13/5-15P
6 Thick Tube Dampeners (for 6SN7 Tubes etc.)
6 Chromed Cones with Removal Tip (1-1/2" Diameter X 1-1/4" High with adhesive backing)
1 Small Speaker Terminal Plate with Pre-Drilled Holes
2 Metal Boxes (Heavy Gauge) with 8 pre-drilled holes; 8-1/2"W x 3-3/4"H x 6-1/2"D (Used for Emerald Physics Speaker Crossover Boxes)
13 Large Male Grille Connectors
4 Smaller Grille Cups
16 Misc Stereo Component Feet
12 10" Long Heavy Duty 1/2" Glue Sticks
LOT 0.110/.250 Speaker Terminal Female Connectors (>50) with Red/Black Jacket
30 1/4" Threaded Nuts for (Speaker/Cabinet/Feet)
15 Misc 1/4" Bolts
1 Tube/Syringe Silver Oxide heat Sink Compound
1 Chip Quik SMD I.C. Remover
1 Jar Heat Sink Compound (Half Full)
2 6.225/6.25 Ohm 50 Watt Power Resistors Mounted on Heatsinks with Cables
1 Behringer Phantom 48V/12V Interface with Power Supply
1 Behringer ECM-8000 - Needs adjustment/repair
1 Unknown Microphone with RCA Output
1 Radio Shack Analog Sound Meters - Extended neck/microphone
1 Stereo 1/4" to 1/8" stereo Adapter
2 Rocketfish AC Travel Charger (mini-USB) - for Mini-DSP Power Supply
2 Theta DaViD (Pioneer DV-424) DVD/CD Drive/New Laser assembly installed
1 Pioneer DV-424 ( Theta DaViD) Remote
1 Used working Theta DaViD Laser Assembly
Note a few items in photos have been sold..... the above list is ACCURATE for what you receive.
SOLD TO Greg!
2 4" Banana Jumpers
15 Misc 1/4" Bolts
SOLD TO Greg!
Lowered Price to $199USD with Free Shipping
I will throw in at the asking price $199USD:
1 NEW PAIR of 3ft Blue Jeans Pair of XLR Interconnects using their best Belden Balanced cable and Neutrik XLR Connectors
AND some other DIY odds and ends as a bonus.
I have the following parts for sale (TAKE IT ALL PRICE NOW $199USD with FREE Shipping to Lower 48 & Canada) :
2 4" Banana Jumpers
1 BNC to RCA Shielded Adapter Cable
5 Hospital Grade 3' 3X16AWG Power Cord with IEC connector
1 NEW Power Cord Male to Female (Medical Grade IEC C14)
8 Thick Tube Dampners (for 6sn7 Tubes etc.)
2 Metal Boxes (Heavy Gauge) with 8 pre-drilled holes for Binding Posts 8-1/2"W x 3-3/4"H x 6-1/2"D (Used for Emerald Physics Speaker Crossover Boxes)
15 Misc 1/4" Bolts
Take it ALL that is listed above for $199USD with Free Shipping to LOWER 48 and CANADA
PayPal for US & Canada & E-Transfer for Canada
NOTE: For ALL other countries (because of weight of the above LOT of Parts) it may be prohibitive to ship but looking in the range of an additional $50USD and 2-4 weeks delivery.
Added 3 Quality Digital Cables for same price of $169USD
I just added some bonus cables:
1 - NEW 5ft Blue Jean Cable Digital Cable - Belden 1694A cable and Canare True 75ohm RCA and BNC Hybrid Cable (BNC to RCA Cable)
I have the following parts for sale (TAKE IT ALL PRICE NOW $169 USD with FREE Shipping to Lower 48 & Canada) :
2 4" Banana Jumpers
4 Hospital Grade 3' 3X16AWG Power Cord with IEC connector
6 Thick Tube Dampners (for 6sn7 Tubes etc.)
15 Misc 1/4" Bolts
Take it ALL that is listed above for $169USD with Free Shipping to LOWER 48 and CANADA
UPDATED List with Added Bonus Items & New Price
2 4" Banana Jumpers
15 Misc 1/4" Bolts
Take it ALL that is listed above for $159USD with Free Shipping to LOWER 48 and CANADA
Hi Dan,
Shall I put you out of your misery?
Consider them sold.
Greg
Thanks Greg! I will reward you with some bonus items.
ALL Sold
