hello everyone,,i had the same issue,,,, could you make a picture of the bottom side and top side of the switches for the crossover and speaker output.. there is a shunt under the switches ,, mine did work but when it vibrated a little it created a short in the circuit..
kind regards
kind regards
Please don't post in a repair thread that was started by someone else unless you are trying to help them.
Start a new thread if you need help with a repair of your own.
I just did .. I said that could be the resistor .. but you did not read the post correctly ..I just ousted some findings that fixed my amp in a past similar situation..
