Hello All,
I have always loved the look of analogue VU meters on an amp, so I’ve purchased a kit from eBay that includes this board. Admittedly it is more for the visual entertainment as opposed to function and I may just have it hooked up to my preamp output.
TA7318P VU Meter Driver Circuit Board Stereo Module Tube Amplifier DB Level IC 889970793033 | eBay
The unit has low level inputs to be driven from a pre amp as well as high level inputs for speaker output level measurement. There is not a lot of info or instructions for the board and the sellers information is translated to English, so it is not very clear and my interpretation of the info is a guess at best. Some research from google has indicated though that the high level inputs should only be used on an amplifier that has a negative speaker connection with a ground reference type which I believe the Aleph J and other first watt projects are. A poster on another site drew out the schematic below. My question is if anyone thinks this connection would damage the output of my aleph J or M2x? My curiosity about hooking it up to the speaker outputs is out of curiosity to see what my amp may actually be outputting when cranked up.
Thanks!
Thanks!
Note that in this manner, the vu meter will not respond to actual volume of the speakers, but from the signal entering the amp. If would want to see the a needle movement proportional to volume control, you will need to wire it after that pote, and if you want constant measurement of the incoming signal, then wire it before such a pote.
You can find simple wiring schematic of analog sweet spot meter in Mr. Rothacher article
http://blog.audiomaker.tech/pdf/lamp part one.pdf Have fun
Hope to see pics when it’s complete!
I will definitely post some pics when I’m done. The meters won’t be built into the faceplate of my Aleph J or M2x. I’m building a stand alone unit that can be attached to any amp I build, which will sit on top of the amp. The over all depth of it won’t be too big so as to not block any ventilation holes. I’ve ordered a piece of aluminum for the face plate and will start working on it hopefully over the Christmas holidays. If this goes well (and I learn from any mistakes), I may order another faceplate for my amp and build it into the case.
Thanks for the link! I will read up on it.
- VU Meter Driver
