If I were to build this, I would
1) build the DC coupled version
2) add linear regulated power supply (like in the WHAMMY)
3) add a passive cross feed before the pot
Maybe some brave guys would make an attempt ?
Patrick
Yeah
That would be very nice.
Even better would be battery operated with regulators.
Nice setup.
How do you like the denafrips dac?
I've had my eye on one for quite some time.
Nice setup.
Thanks. I love it, highly recommend.
I wasn't happy with the first enclosure I got for the ACP+ so I ordered a Galaxy 1U case from Hifi2000 and it's great. Now it looks good and sounds good.
How do you color the cnc letters in black ?
I ordered the front panel with engraving, filled the engraving with black enamel paint and lightly sanded the overfill off. Modushop doesn't fill engravings but Font Panel Express does if you don't want to diy.
@genechow great job! I was perfectly happy running my ACP+ naked until I saw your chassis. Would you mind sharing the front panel design file?
Thanks,
Olen
Here you go. Enjoy!
Try fingernail polish, it dries fast, and remove the excess with acetone. Fingernail polish remover is made with acetone. Just use the full strength, unscented kind.
TJ
I'll give that a try after noticing the sanding marks on the pics. I am not a great painter....
Photos of the not-quite-final BAF'19 Workshop PCB, but close enough that it's fine for illustration.
This looks gorgeous!
I'll probably still be trying to work out those PSU-riddles when it becomes available
- Amp Camp Pre+Headphone Amp - ACP+
