Single touch power on/off switch
Hi guys.
I'm looking to power on my 2x15W JLH from a physical on/off switch in the back and a one-touch button on the front. I want the touch button to turn on the amplifier when I first press it, and turn it off when I press it again.
This is what I've found so far, from eevblog...
https://imageshack.com/i/p9BJywFXj
However, this needs two different touch-buttons, which is both unpractical and uncool. In my head, this modification makes sense and will work, but will it?
https://imageshack.com/i/p3q0gmj5j
I've forgotten enough about electronics, I cannot figure out this myself, therefore I'm turning to you guys, perhaps this can help others as well. 😊
If this is a dead-end, please enlighten me, how can I easily make a simple on/off switch from one impulse switch/touch button. Got relays, bd139/140's, got diodes, caps, resistors... Just doesn't have any dedicated chips or 555's or whatever...
PS: tried to upload the images here first, but was missing a security token of some sort...
Sincerely grateful...
Ben from Norway.
Moderator
Joined 2011
Hi guys.
You could use a latching relay that changes state when there is an input. Here's more info.
https://en.wikipedia.org/wiki/Relay#Latching_relay
Something like this ? :)
Mona
Administrator
Joined 2007
Post #13 here using a single 4013 CMOS chip. Its drawn as positive earth but the operation of the circuit is unchanged. You could use this to power a relay and arrange a simple constant voltage PSU for the CMOS chip (small 9 volt PP3 type rechargeable battery charged from the amp supply. Current draw of the circuit is essential zero)
http://www.diyaudio.com/forums/head...le-ended-class-headphone-amp.html#post2080579
Mona
Very smart: I was about to propose something quite similar :D
It is also possible to use other "active" devices: a SCR or a relay for example.
Note that depending on the load (bypass cap, etc), it might be necessary to add components like diodes, to make sure the latching in the on or off condition is reliable.
With a resistive load or via a relay like here, this is not a problem.
. Never tryed it but could function like this ??
Mona
Possibly, but low power tetrodes thyristors (=PUT) are a completely different breed: they were used in ring counters for example, which means they can be turned off more or less at will, a bit like the simplified NPN+PNP equivalent schematic (which is completely invalid for power SCR's)
Recently I got this PM,
RSK said:
Hello Mona,
I wonder if you could assist me please.
Am looking for on off switch with CD4031 or similar
to activate relay for AC supply to transformer.
I requuire one specific function, a Bicolor LED to
indicate on and off.
Have you any circuits please.
Raj
Since I feel it isn't a question to ask via PM so I put it here with a proposal.
Mona
