Dear sir
In ax11 ampl.can i use njw038gand0281g in place of bd249 and 250.thank .
Use this schematic
Have you got shares in transistors companies ? lol
I can get a good sounding amp with 1/3 as many transistors.
what's your idea about ax17? you made that?
how can i replace a1837/c4793 with other's such as tip41/42 or tip31/32?!!! what's max power suplly?
APEX PSU 60 with protect, PCB NOT YET TESTED
for diy use please design in one layer.
Gerber APEX PSU 60 with protect, NOT TESTED
hi where can i find that gerber files for ax14
sir
in ax11 i use mpsa42 with changing collector,emitter resistors in place of mpsa13 .my voltage drop and mpsa42 burst.please give me solution.thanks
Yes but resistors around MPSA42 must be change, use 2k2 from base to colector and 1k from base to emiter.
Sir if i use bc517 in place of mpsa13 what cpllector and emitter resistor would be change.thanks dear
Hi there . I use the protection shown in the picture for ax14, but when the bass goes higher, the capacitor marked with a red circle inflates.
There are at least 2 mistakes on this PCB. 4148 at the left of NE555 must be reversed and also 4th leg of NE555 must be connected with 680K resistor, 100/63 cap must be non-polar. Also sensitivity on negative input voltage of this protection is weak (about 4-5v). But I used it in couple projects and it saved my speakers couple times though...
Hi. Thanks for the help.
But even with the correct component direction, the same error is a bit bass, capacitors are over.
I'll look at the transistors and ne555.
some one is using my macro designs cool 😛
- 100W Ultimate Fidelity Amplifier
