So I have a Session 500 on the bench now. I can't seem to get the preamp section removed from the cabinet!! I have the amp section removed all connections off and the preamp will pull out the back about an 1/8 inch and then hangs up. The rear corners have been removed also. What is up!! What else has to be removed?
Well, there was only a 4 minute window between question and self answer 😀}Glad I could help.
For the record, you have answered me, including searching for and posting a Service Manual PDF within 15 minutes of asking 😱
Thanks, JM, but you are about two hours earlier time zone than me, I think that is probably why. Or maybe a SOuthern Hemisphere thing?
- Live Sound
- Instruments and Amps
- HEY ENZO!!..Peavey Session 500
