I'm clearing out some older parts. Everything is unused and in mint condition. Deals to be had if you want the lot!
Two par-metal aluminum enclosures
12 x 8 x 2.5
Clear anodized front .18" Thick
Black anodized body
included is an optional divider plate, mounts 7 1/2" from the right hand side
includes case screws
no scratches or dents, have not been drilled.
photos show a bit of dust.
SOLD
One toroidal transformer
Originally bought as part of a group buy for use with a dynahi PSU, there are many applications...
Avel Lindberg AT CE6558
Primary: Y23 type 115 + 115V 50/60 Hz 80VA
Secondary: 35 + 35V @ approx 1A
Size: approx 4" x 1.8"
Finish: encapsulated mounting
$50
One Elma Ladder Attenuator
24 steps
04A2R00
unpopulated
(These are really well made attenuators. Some of the best you can get.)
dimensions:
43mm max width
102mm in length overall
80mm from behind the nut to the back
6mm shaft
10mm clearance hole needed through the enclosure
details here
SOLD
Two dynahi boards & two dynahi psu boards
These are original version boards from the first group buys all those years ago.
All are mint and haven't had components mounted. Are they still buildable? Maybe?
If you are interested, PM me and we can work something out.
teflon coated silver wire - 65feet
Solid 24 awg 99.99% silver wire with .002" PTFE (teflon) coating.
SOLD!
Four Vampire RCA chassis mount connectors (two red, two white)
These are the best they make. See here
Gold plated with an isolation washer.
Part #CM2F/CB
SOLD
12 x 8 x 2.5
Black anodized body
SOLD
$50
24 steps
04A2R00
unpopulated
dimensions:
43mm max width
6mm shaft
details here
SOLD
SOLD!
Part #CM2F/CB
SOLD
I'm interested in the RCAs. Please how much shipping cost registered mail to Catalonia - Europe?
What's the max. diameter of Elma switch?
RCAs are pending.
Elma diameter is 36mm. I added a link to the OP with some information on it. I'll grab more dimensions when I'm home.
I have the Elma and remember it's 40mm. Please double check.
Yeah i was just going by that linked site as I couldn't measure mine at the time.
Just measured mine, it's 43mm
RCAs are pending.
Are the RCAs sold?
