Hello every one,I plan to only clone the ARC SP16 Preamp,which MOSFE can be used for the Q1(1036)? is there any way to use a tube for this ccs? any comments or suggestion.Really appreaciate.
A number of depletion mosfets like the DN2540 will work fine. And so will a pentode. R36 will obviously need to be adjusted.
But why clone a preamp which was never known to sound any good? Even ARC themselves saw a bit of light and moved onto higher current, nfb free circuits.
thanks ,just want to try it.Never build a preamp like the differential amplification.I would like to use 12ax7 Parallel connection cathode output
Your on the right track, below is an example of a similar setup using 6SN7’s this arrangement sounds fabulous, if you want to stick to 9-pin tubes I would use a 6CG7, use a MOSFET as a sub for the cathode follower.
And LM334 as a ccs.
The gain is adjustable as well.
Quite agree, I see one problem on first glance with their scheme, the first triode needs a coupling capacitor after the 300K load resistor, over time their would be a tendency for the circuit to start motor boating!
And LM334 as a ccs.
Is there any obvious differences between 6SN7 and 12AX7 for the input
differential amplification. can we use tube as ccs to replace for the LM334
Huge difference in tubes, two different beasts, the 12AX7 requires much more feedback to achieve a reasonable gain for a line stage, and the 6SN7 is a much more linear tube to boot.
You definitely could use a tube for ccs, but you would have an additional heater supply, and a much larger negative bias to worry about and I don’t know if it would perform, or sound any better!
Your on the right track, below is an example of a similar setup using 6SN7’s this arrangement sounds fabulous.
Looks like something I might try. Couple of questions.
- Do you know the HV supply needed?
- No load resistor in the first triode?
- What is the gain?
Thanks.
- What is the gain?
Thanks.
Its also a diferential schematic, it doesn't need a resistor the CCS fixes the operating conditions of that triode, the gain depends of the tube, with a 6sn7 will be like 10 (I'm guessing 😎) the HT something like 100-200V (IR820 has a rupture voltage of 200V Max) you can use a DN2540/IRF710/FQPF3N60...
You may look for a low Crss miller capacitance in those something like ~50 pF or lower if you use a higher capacitance one it will have a low slew rate or may oscilate with ease
6SL7 is similar to 12AX7,but the size is bigger.How about a 6SL7 (as in the Octal Cornet)?
- What is the gain?
Thanks.
I’m running them at 250VDC, the first triode is basically a cathode follower. The gain can be set from about 12dB to about 18dB, depending on the ratio of the feedback. I think the variable resistor should be around 25K instead of 10K.
The 334 is set for a 10mA cathode current.
I read somewhere that the 6SN7, 6SL7 internal structure was symmetrical, unlike the 12AX7. Stated they sound better?
I have heard the Octal Cornet and it was very nice. A lot of neat design features.
I also like 6DJ8 and 2SK170/417a phono stages.
BTW, I'm not promoting or knocking anyone's design, just thinking out loud.
I hope the original poster is finding what he is looking for.
I wouldn’t worry, we should think critically about others designs! I don’t like a 12AX7 in a line stage, for one is the higher impedance one has to work with even using one as a cathode follower. It doesn’t mate well with low impedance SS amplifiers.
The DN2530 MOSFET for 1039 is the best match. The DN2540 may be a little low on current unless you adjust the resistor.
Totally true with FETs - however there is no adjustment provided. I may be the 1036 is supplied for a certain pinch off. DN2530 seems to have a high pinch off in simulation although is not clear from the datasheet. The simulation models are from microchip website.
- Tubes / Valves
- ARC SP16 preamp Clone
