I tried it with an ECC33.
I just made an adapter and tried it in a single triode phase splitter and voltage amplifier.
It made no difference to the sound or evenness of clipping when driven over full power.
Being over the other side of the ocean the trial tube was a 6/30L2 however an ECC83 could be tried.
The vintage amplifier can be restored to original in seconds with an adapter.
What's this????
Electrical equivalents to 6SN7...
Tube Tester Files - 6N8S - 6H8C
7N7, Tube 7N7; Rohre 7N7 ID3955, Double Triode
6N16B and 6021 are 6SN7 with lower Pd in subminiature (pencil tube).
6N16B-V | Tubes Information
Use two 2C22 to replace one 6SN7. Best sounding 6SN7 replacement there is, in my experience. SiC Schottky diode bias in the cathode makes it even better.
Have you ever compared them to the 6J5GT's?
And when tube specs are significantly different, they need different values around them in order to have optimum performance of each tube type.
Resistors, current, voltage.
This is one reason why I am interested in the 6CG7 the specs are the same as the 6SN7...
- Tubes / Valves
- 6SN7 Equivelents
