Headphone amp wit built in ES9038 DAC board
This is my music at work. Sounds really good wit my B&W P7 headphones. E88CC with Giatras output irons 75ohm. Just plug in USB-source and play. Best with HD tracks but works good with Spotify too. Dont want to go home 🙂
Note the inside picture is before I put in the DAC board with USB. It has the same supply as the heaters.
Joined 2009
This is my first experience of building a tube amplifier. This is RIAA corrector.
very nice, what tube did you use for the riaa? ......enjoy the music 🙂
All tubes are made in the USSR in the 50's years of the 20th century. 5Z4S (5Z4) on power supply, 6N9S (6SL7) and 2 x 6N8S (6SN7)
I loveeeeeee Russian tubes, I am using some of them on my projects but first time see those tubes...thanks
I'm using 6N14P, 6N2P, and 6N24P in my latest RIAA. Soviet tubes FTW!
Hi kodabmx,
oh I am looking right now for a new riaa preamp, I have available 6n2p-ev and 6n23p, how is your latest riaa, can you share the design? All the best, btw always looking at your project, I think you are one of the most eclectic member of this forum,,,,,all the best 🙂
nice, where did you buy those switches?
From here: 19mm Metal Waterproof 12V LED Power Symbol 5Pin ON-OFF Car Push Button Switch | eBay
- Tubes / Valves
- Photo Gallery
