What causes grainy sound
I can
But your ingrained teachings that phase differences are not audible will negate it.
Before I started getting deeper into speaker xo design I had the same problem Stereo effects were all over the place and cohesion of the soundstage was difficult even with the best speaker placement/LP.
Then I started to learn about phase alignment and things got better with xo manipulation, then I involved dsp into the mix ......after about a yr of hardcore testing (including some measurements) i’ve found I can focus the stereo field through phase alignment.
It’s a precise adjustment with a focus point that can be moved at will but always centers in the same place (repeatable) and when centered there is a holographic cohesion of the soundstage that is absolutely engulfing.
This is what I believe was the ‘it’ I was trying to figure out awhile back.
So in other words those that are more sensitive to Not perceiving the stereo effect are maybe just out of focus.
Don’t ask me the technical particulars because I really have no clue......but I know it is repeatable. And more than likely it’s system/room dependent so it’s probably going to be a one off personal custom tune that would involve both dsp and active/passive hybrid xo’s.
If it were just a pan then the balance knob would do the same thing....and whether balance is changed in analog (on reciever) or dsp it doesn’t do the same thing.....it’s just a 2d change......I’m talking 3d
Edit......this is a bit off the wall but what if we had a sweet spot in stereo perception that could be focused much like glasses for sight ?
Are you talking about yourself, Scott? I'm not aware if a man with 'normal' ears can't perceive stereo effect. Otherwise he wouldn't know what a stereo is.
No, Planet 10 quote :
"Do note that some 10% (Lynn Olsen’s estimate) of people are not capable of forming this stereo image. One could speculate that that is a reletively recent evolutionary adaptation, otherwise these “guys” would probably be tiger food"
I don't follow the logic of his speculation.
Well whatever I might be doing the best way I can describe the focus point.....it’s like being in a snow globe with the performance.
A larger lp (over a meter) as compared to the proverbial head in the vice
A clarity and dynamic that is so real it makes your hair stand up
I’ll take it whatever it is! 🙂
I don’t know how long ago it was when I first brought it up (months for sure) but since then I’ve concluded that it is a physical change that is repeatable to the same settings, also those settings move with each tweak but are still repeatable.
Maybe I’ve stumbled across the point where perception meets reality?
Edit.....would like to add that this isn’t a price bias thing my system is mid fi at best and totals only $1500 invested.
