ESP P97
I have not modified the circuit. I have only used another PCB.
Hello A4 brilliant for photography; laser printer with strong toner and transfer to fiberglass plate with copper layer 1 side only with heat (plate) or with acetone (there is a tutorial on transfer with acetone on youtube).
Share pdf if you can. currently i do not have opa2134. i want to finish this proto-board with tl072 :violin:
I have seen it already, youtube.
i don't have alcohol & acetone.
BTW thnk u for the support :)
