PSU for a specific board level amp
Hello,
I am looking for a small project to build for a kitchen stereo. I found a detailed analysis of this board:
20W HIFI Mono Channel LM1875T Stereo Audio Amplifier Board Module DIY Kits | eBay
The review was very thorough and found it to be a good design for a small single channel amp. My plan was to get two of them, and pair it with a 25V PSU. I don't think it's good enough to justify an expensive PSU, but I still want to buy something safe.
Can anyone recommend a decently safe, inexpensive, dual-rail 25VDC PSU?
Thanks,
Brian
Hello,
Thanks,
Brian
Hi Brian,
Unless you have a particular preference for class AB (LM1875) and want to improve this very simple board, I will recommend you something cheaper, equally good and with less problems. Buy a class D stereo board based on the TPA3116 or alternatively the TDA7498. Buy a cheap 19V laptop power supply "brick" and eventually add a 4700uF power line decoupling capacitor and you are done.
LM1875 can play very nicely but it has issues with stability, issues with "fake" chips (if cheap), requires a good heatsink, needs better supply line decoupling than shown and a symmetrical power supply. A symmetrical power supply is considerably more expensive than a standard 19V laptop "brick". So unless you really WANT LM1875, the class D solution is less expensive and less trouble.
Sound wise the TPA3116 or TDA7498 is very good, not perfect, but you say yourself that it is for the kitchen.
Hi FauxFrench,
Thanks for the reply. I need a 4 ohm unit, so I found this unit to be recommended with the TPA3116, and seems to require about 20VDC and 2A per channel:
DC 12-24V TPA3116 D2 100W Mono Channel Audio Power Amplifier Board for Car TE633 4894663151645 | eBay
I would be looking for a ~20VDC 4A PSU to drive two of these. I don't currently own any supplies of that voltage, so I will have to buy something. Do you have a recommendation for the PSU in this range?
Update: I was able to find this power supply with V+/- terminals that can output a max of 4.5A and it costs $17.87 at time of this post. This PSU, I think could be used with the LM1875.
https://www.digikey.com/products/en?keywords=lrs-100-24
For the TPA3116, I found this generic laptop supply on amaz for $25.90:
https://www.amazon.com/ZOZO-Univers...&sprefix=19v+laptop,toys-and-games,121&sr=8-5
All things being equal, that means I will have so far spent:
LM1875= $4 for amp boards + $17.87 for PSU = $21.87 (must include heatsink, which I already have many)
TPA3116= $20 for amp boards + $25.90 for PSU = $45.90 (no need to use any of my heatsinks)
So, I would ask if you had any opinion about these two options? Objectively, it seems like the TPA3116 will cost twice the LM1875. (assuming my chosen PSU is okay) Even if I include the cost of the heatsinks, it would still be slightly cheaper.
https://www.amazon.com/ZOZO-Universal-Notebook-Ultrabook-Chromebook/dp/B0132ST35Y/ref=sr_1_5?crid=33HCYWGWO0A08&keywords=19v+laptop+power+supply&qid=1569249863&s=gateway&sprefix=19v+laptop%2Ctoys-and-games%2C121&sr=8-5
I have some other suggestions for a TPA 3116 amplifier with power supply.
As far as I can see, the nice Meanwell power supply you suggest for the LM1875 is single 24V and will not do. It needs to be a symmetrical power supply.
TPA3116 power supply suggestion:
2.5x5.5mm Laptop AC Adapters Supply Power Charger for Toshiba ASUS 19V 4.74A 90W | eBay
Amplifier suggestions:
DC 10-25V TPA3116D2 HIFI Digital 2.0 Dual Channel Stereo Amplifier Board 2x50W 822933247723 | eBay
DC 12V 50W +50W TPA3116D2 High Power Digital Audio Amplifier Board S8W2 194452631278 | eBay
https://www.ebay.com/itm/2x100W-TPA...=311567426011f60d743492b740d3b23b787ca4e94b7f
https://www.ebay.com/itm/2-0-HIFI-l...925369&hash=item3f6a41c390:g:XzsAAOSwknJXzX20
https://www.ebay.com/itm/DC-12V-24V...604560?hash=item2ad5345ad0:g:ShIAAOSwHX5dhwcR
The LM1875 boards you suggest will need 4x4700uf replacing the small ones presently on the board. What about volume control?
Hi FauxFrench,
Thanks for your feedback and suggestions. I have a couple questions from that.
Okay, thanks for the info. I was confused because the power supply has four output terminals, two labeled 24v+ and two labled 24v-. Why would they have four terminals if it wasn't symmetrical?
I am comfortable ordering and swapping out a couple caps if I get that one. For the volume, I was going to use a passive volume control between the devices and the power amp. (except for the turntable which has it's own preamp)
I understand your logic. Perhaps you can connect two LED strings. When you read the "Product Attributes" it becomes clear that it is 1 output with 24V.
OK with a passive volume control. You have thought about it. You talked for a start about a "kitchen stereo". Now you talk about a turntable (in the kitchen?). My impression was that you wanted a simple MP3 or Bluetooth setup to please your wife.
Digi-Key (and others) use stock images for a product series, so the details on the image are not representative of the exact item you will receive.
HCC24-2.4-AG Bel Power Solutions | Power Supplies - External/Internal (Off-Board) | DigiKey
That is the cheapest 24v split rail PSU listed at 2.4A per side. Not cheap at $145 though...
Hahaha. Yes, it's something like that. However, I also use the kitchen area to read and relax. I've been collecting turntables and such for a long time, so I always seem to have one to hook up. There is also a cassette deck, a tuner and a bluetooth connection that get heavy use by the lady.
I think that particular one is the right image. I did a google search for the model, and all images of it come up with the four terminal outputs and the +/- labels. I believe you all that it's not symmetrical, so there must be some other reason for it.
In any case, over $100 is super overkill for what I'm doing, but there seems to be some less expensive hobby boards out there. Anyone have experience with this:
LPS215A | Connex Electronic
Thanks,
