Speaker Wires, analysis and results
Skinny cable
Aren’t the DNM cables also somewhat skinny?
dave
This is the original DNM dark grey and the conductors are 0.6mm in dia each.
As per my original statement, my brother is an electronics engineer (telemetry etc) and is not gullible or a fool. HE would be the first person to shout "Snake Oil." There was a difference.
He later on told me that probably due to the fact that the Quads have an input transformer, that changes in cable inductance and capacitance could affect the sound.
Definitely not litz
@ ferret:
The "normal speaker cable" was litz;-? The DNM "solid core".
That is the answer;-)
Nope, it was in fact pretty normal. Can't recall exactly what it was but similar to Monster, around 1.5mm dia.
The speakersw had been left on for 48hrs to charge before even attempting to play them.
With reference to this on Rod Elliott's Website Interconnect and speaker cable whitepaper
See the section discussing the input transformers
Just BTW, I have never been able to afford the high end cables, nor would I ever try them. Prefer to spend money on maintaining the Quads, amps and front end equipment and adding to my music collection. Just used my commonsense and ears. Directionality? I don't think so! That goes for cryogenic treatment etc. Though due to my OCDness I do like conformity, so I always have the writting starting from the "source" point ;)
frugal-phile™
Joined 2001
I gave the hint to you a long time ago. You should have googled it yourself.
From Wikipedia:
Some of the benefits of cryogenic treatment include longer part life, less failure due to cracking, improved thermal properties, better electrical properties including less electrical resistance, reduced coefficient of friction, less creep and walk, improved flatness, and easier machining.
dave
Cryogenic treatment definitely has its place in enginering of metals etc. I have been trying to get hold of a few papers on Research Gate as a matter of interest.
I just don't have the money to afford these cables - and I probably don't have the ultra-fine discerning ears to be able to tell the difference between a cryo-treated cable and an untreated one. Ideally of course they must be identical (same manufacturer) one made with treated and the other untreated cable.
My hearing though is good enough to hear differences between different speakers in different rooms, effects of different front ends (digital or analogue) etc. But to all intent and purposes my system is as good as it can be currently. My DIY is currently aimed at restoring some TTs, trying different tonearm / cartridge combos, and getting the best I can out of the LPs and CDs in my collection. Also building a few new and rebuilding some old RIAA headamps et al.
