Sony Speaker, Big problem for me, small problem for you
Hello everyone,
I search on this forum but I didn't find a solution for my problem. It's a tricky problem for me but for you, the proffesionals, probably it's a problem with a very simple solution to find.
I have Sony N9200w home theatre and I love it!
The problem it's with the Front-Left speaker, sometimes I think that something it's wrong with the sounds and I don't know how to test it properly.
There are some sounds that doesn't sound right, it happens randomly.
Netflix Intro, PS4 menu navigation( the hight pitch notes) and sometimes in classical music.
I tried to put the left speaked plug in the slot for right speaker, it happens like before but I think the problem it's solved after 4-5 tries.
Yesterday, while watching a Netflix movie, was a scene with a door slaming and I heard a noise from that speaker that doesn't sounded right, after I maked some test for aproximmative 2hours and everythings seemed to be fine, the problem happens randomly, I tested with some classical music that before sounded wrong. Everything was good at that test.
Can you help me, please, with this problem?
You know a proper way to test if the speaker have a problem or not?
THANK YOU ALL!
The above description is unclear.
If you suspect the left-front speaker to be faulty, then swap it with each of the other three speakers in turn.
If the problem stays with that particular speaker regardless of what position it is in, then it is faulty and in need of replacement.
I will do tonight the swaping method. Until yesterday, I only swapped the inputs from the back of the amplifier with the Front-Left / Front-Right speakers but also in this type of testing, might be the cord faulty and testing was compromising.
Do you know a very good test for testing the speaker? a flac file or something like that that can help me better to find if the speaker really have a problem?
