AMP , I have already a good sample of the tpa3255 and parallel I am designing a ground breaking discrete class D and will chose between the 2 based on SQ testing.
How can it outclass my existing Volt D+ amp?
THD is 126.8 , supercaps ... on opamp rails... (never been done before), no asrc , pre IV filtering (and it was not an easy task to keep the great THD while filtering the DAC output)
Great achievement, what about the SQ?
Matt
Amp , not finished
Sound quality of the DAC is subjective but we fallowed what audiophiles have been saying for a long time . No jitter , no asrc , low impedance (lots of electrons on the rails) and of course low noise on each rail .
What is funny , is that most of those hardware improvements (sq) have clearly showed up as improvement in THD ... we jumped from -121 to - 127 (same layout same PSUs)
THD +N is same from 1Khz to 19.5Khz (in fact slightly better at higher frequency since THD improves of course)
Power amp needs at least 50V, we are designing the PSU that comes along with it but right now its too early to give more details.
Power of the AMP is given by the formule VxV/R (speaker)...so in case of 50V (2500/8) = theoretical 312W but efficiency and other factors affect it so I would say 150W (at that voltage)
Last thing , I am having lots of fun with the new design , its like Kali but with comparators (new for me) and level translators
Last few weeks , I have stopped my usual chess games to fully concentrate on it. Really fun even though it might not bring anything...
I am eliminating any global feedback in the amp and concentrating at SQ at expense of THD+N
Pics of the final box with/without sig
Can't wait, if i does for USB what my DigiOne Sign has done for my coax dac. Taking preorders?
Awesome, will ALLO be taking preorders soon?
Does this mean the DigiOne Sig will no longer require a separate clean side input?
Thank you!
I am discussing preorders with the team will update you soon .
Digione Sig needs a "clean power" note the hole (unpopulated) next to earth
We received the PCBs, all components and order was placed for alu boxes. As soon as they are received we are good to go. (meanwhile we will start mass production)
Will it be possible to buy Digione sig and revoltution Dac without their boxes?
Thank you
Thanks, now I see it. I probably have to cut the hole bigger to fit the Type-C plug, my Shanti is adapter free
What does with/ without sig mean?
I can see the one has two additional Outputs...
One bring Digital toslink and the other one?
How will they differ in function and price?
Im planning to use it with my USB dac. So probably the simpler Version will do for me?
Thank you.
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
