With reeds and other relays, it is not only a contact issue but the field from the coil.
Yes, that magnetic field is clearly audible. Barkhausen noise modulation creates intermodulation distortion through non harmonic spectral components. Interesting enough, it happens only for the reed relay magnetic fields. Other relays don't have the same type of field from the coil.
Impossible, or just impossible to achieve something specific perhaps?impossible to use passive crossover with a current drive
The M2 is a package which includes "digital" power amps with DSP crosover. So no. As soon as I get them to Bangkok and have the analog amps then definitely that is a YES. I have already measured the cross-over characteristics i need when I replace the digital amps. Why do you ask?
THx-RNMarsh
BTW --- I did the current feedback -- the data I published was of a 3-way JBL system, How Nazi propaganda encouraged the masses to co-produce a false reality.
THx-RNMarsh
I was almost going to post a few weeks ago that we've somehow managed to avoid Godwin's Law on this thread, but it seems that it's inevitable.
Reed relays are pretty marginal for audio. Of course, everybody in audio knows that. I'm still for silver on silver Shallco switches. They work and sound great! I have had mine working for almost 20 years now in my CTC Blowtorch.
...we've somehow managed to avoid Godwin's Law on this thread, but it seems that it's inevitable.
It naturally would seem to follow the mean-spirited dirty politics debating methodology of some. Obviously, the conduct does not rise the level of you know who, but its still playing dirty politics under the guise of audio. Maybe that's what makes forums successful, I don't know.
Impossible to get requested improvement, because passive crossover with its parallel impedance branches does not allow for a true current drive.
???Impossible to get requested improvement, because passive crossover with its parallel impedance branches does not allow for a true current drive.
RNM
Because as I said, lip service doesn't count. Show the results, and hopefully they are credible and reproductible. Scott just mentioned his results, and I have no reason to doubt them, since they match my own practical experience (mind you, I have myself a considerable experience in the same semi industry, different branch).
I already have. In this thread. Resistors, capacitors and relays have all been shown. FYI some non reed relays also place a steel signal conductor in the magnetic field and have similar issues.
Barkhausen effect occurs in a changing magnetic field, not really an issue with a stable DC supply to the relay coil. It was used as proof of the existence of discrete magnetic domains. You really do seem to like discussing things with little knowledge of the subject.
Rather inaccurate assessment, line level passive crossover is a valid option for a multi amp system....impossible to use passive crossover with a current drive....
You know what he meant. Why would anyone use a line level passive crossover anyway? Seems stupid when you can do a much better active or DSP version.
Ask Planet 10, he loves them, don't know why, he's into minimalism (the less in the signal path the better 🙄) and doesn't sell them (or the concept) maybe?
The more astute of you can probably work out what exactly happened here.... Speaker question: WAW / FAST
I repeat that all the speaker mfr that make the best drivers possible.... JBL etal... dont seem to do as well when it comes to amplifiers. Not there forte.
THx-RNMarsh
What about the likes of Kii?
.. and contacts -- who needs actual switches or relays in the signal path any more, anyway?
"and adds none of the electronic haze any active XO gives". (Planet 10 quote)
Where's yours? 😉
Where's yours? 😉
There is a guy here who has designed and built it. With in-wall speakers. Unfortunately, I have not heard it, yet.
I did a number of experiments with a setup where the output impedance can be dialed in from lowish to highish. Not all drivers work better with current drive, and some drivers work better with voltage drive for high and current drive for low frequencies, or the other way around. It is very component specific.
Bruno uses a split current/voltage drive for the Kii woofers. Really not that hard to do. Point is: it depends on the driver what kind of drive delivers the lowest distortion, and it is frequency dependant as well.
Rod Elliott recommends experimentation with a combination of voltage and current drive because as you say it's specific to each driver
Simple and gets the job done well enough, I tend to trust Murphy. Better for you may not be the same for me. 🙂... Why would anyone use a line level passive crossover anyway? Seems stupid when you can do a much better active or DSP version.
Devialet is another one. Not sure what they do - or if they are any good!
It'll be interesting to see Purifi's "new" drivers when they appear.
DSP is simpler, really, and much more flexible and accurate. And far easier if you want to try several variations!
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
