For the cost of two plate amps you can buy a behringer inuke 3000DSP. That's what I use.
All the components of my system are black, so I would go for the NX3000D, but I can not see how it differs from the INUKE series
Does anyone know?
Sorry OT
NX3000D | Portable | Power Amplifiers | Behringer | Categories | Music Tribe - Behringer)
Thanks guys .... I have Crown Xls 2502
First il try the subs in corner placement. Il share the pics after building them.
I'm not familiar with the NX3000D. Does it have a built in DSP?
Yes, you can see it in the link that I attached above.
In a quick read the specs seem to be the same as an Inuke 3000 DSP.
Maybe they are the same, just with another aesthetic ..
That's what we expect, many photos!
Good luck with the project !
Well ... I ended up building a H frame subwoofer with PRV15W700
I tried seald box, it was huge, and it sounded a bit boxy.
May be heavy bracing will solve the issue to some extent, but I assumed it is not possible to completely eliminate the boxy feel.
So I built a H frame ... sharing the pics (please see the attachments)
Hi All,
I am trying to build sealed subs with 15" pro drivers.
In simulation with 100L box, I am getting the F3 values as shown in the attachments.
Aren't these F3 values too high for subwoofers??
Do they even sound like subs with these values?? Or do they just end up like mid bass?? Will they give tight and punchy bass for music??
We expect subwoofers to go down to 20hz or lower. So I am wondering if higher F3 is ok with larger drivers like 15" or 18"??
Should i look at drivers with rubber or foam surrounds?? Does it matter much?
I dont want boomy bass. Good transient responce is important for music.
Thanks in advance
Hmm. Eminence Alpha 15A? I can get better than F3 of 53Hz in an open baffle of 120cm x 60cm. To do that usefully, it has a 2nd order 200Hz lowpass, and it doesn't go over about 100dB. Pretty sure they're not really sub drivers at all...
My current bass boxes are 12" Lambda's (now from AE) in 60l each (sealed). The design says they're down 12dB@20Hz, but in room and with sufficient amplifier grunt, they satisfy.
- Subwoofers
- 15" sealed subs - simulated F3 values too high ??
